Installation & Licensing
Unable to activate Maya 2014 error 110
59 REPLIES 59
Message 1 of 60
48244 Views, 59 Replies
hello everyone
i have just upgraded to maya 2014 and im unable to activate it.
Installation runs without any problems then when i start maya i see the activation screen and as soon as i click activation i receive a licensing error code 110
when i click ok i get this dump
License was not obtained
Tried Maya 2014 (657F1 2014.0.0.F), error 20
License method:
environment variable MAYA_LICENSE_METHOD='standalone'
Product choice:
environment variable MAYA_LICENSE='unlimited'
License file override:
environment variable MAYA_ALT_EN is not set
i am using Osx 10.9
59 REPLIES 59
Message 41 of 60
jessica.t
Welcome to the Autodesk Community, Max!
Sorry for your activation troubles, although you have already installed Service Pack 3, will you try the other troubleshooting steps in this solution?
Please let me know how it goes. Thanks!
Jessica Thrasher
Message 42 of 60
It's still jumping. Nothing happens.
Message 43 of 60
Hello, could you tell the step by step commands to run in Terminal, I have the same activation problem and do not know well uasr Terminal. Thank you.
Message 44 of 60
in reply to: aaronhai
Message 45 of 60
Message 46 of 60
in reply to: NymphRedil12
amir, I like a person previous to me, had to do it two full times. It worked.
Message 47 of 60
Regarding the terminal: I am new to this as well but it worked for me. Just had to do it a number of times. Remember, the terminal deletes files that can be deleted manually, if you know where they are (I forgot how to do it- but I did this manually).
But for those that want to do it by terminal... just open the terminal and type the one command in the solution and press enter...done.  Nothing to it.  It deletes some files.
Message 48 of 60
mogworks
Thanks azatelli - this worked for Maya LT 2014. Here is the link to SP1 if anyone with the same problem needs it:
Maya LT SP1
Despite you mentioning this back in December, Autodesk still have not updated the link. I have just lost a days worth of work messing around hacking and deleting files trying to fix this problem - something I know nothing about and it turns out Autodesk just haven't updated a link. Frustrating!
Message 49 of 60
pendean
Message 50 of 60
in reply to: pendean
Ran into this problem recently on Mavericks.  I have a student's license.
1. opened the Maya Terminal.term tool found in the Maya directory.  this will open a terminal shell.
2. entered the following commands where <Product Key> is your 5-digit product key:
      "adlmreg –u S <Product Key> 2014.0.0.F"
      "adlmreg –u N <Product Key> 2014.0.0.F"
3. moved the Maya 2014 directory into the trash.. it's still there since I didn't empty it.
4. Downloaded and installed SP3 from:
http://beehive.autodesk.com/community/service/rest/helpportal/resource/helpportalchannel/docnlink/js...
note: The installation already knew my license and product key so i just left it in there and hit next until the install completed.
5. Started Maya and saw that it automatically went to validate my license.  Success!
Message 51 of 60
alexandrameza941
in reply to: ase37
Same here! I can't install Maya 2014 Student on my Macbook Air. Any ideas?
Message 52 of 60
in reply to: grace.liu
grace.liu's link(s) worked for me!
Message 53 of 60
I only got
Pit file removed.
But no prompt on re-activation of product key..
Help please!
Message 54 of 60
david.lau
Message 55 of 60
in reply to: david.lau
thank you for the help! it worked well! Woman Happy
Message 56 of 60
Because of various reasons Mac speed gets affected and cause various problems. Junk files, large amount of data on a single drive, malicious files are common cause of slow speed of Mac. To get rid of this situation you need to use MAc Data Recovery which recovers lost files and speed up Mac performance very easily. If you are getting Unable to activate Maya 2014 error 110 error it means Mac device has got some problem which needs to solve.
http://www.restoremacdata.com
Message 57 of 60
I downloaded the student version of 2014 and keep getting the error message when I try to activate it.
I'm running the Mac OS X Yosemite beta 10.10 and Time Machine is not turned on.
Any help would be greatly appreciated. I have to start using Maya for class assignments soon.
Message 58 of 60
jessica.t
Hi @Anonymous and welcome to the Autodesk Community!
Did you try @david.lau's solution as marked above? What was the result? Did you see any changes? Please let us know!
Jessica Thrasher
Message 59 of 60
what if you never set up time machine and it still has error 110, error on install exit, and wont let unistall because two asian languges are being used
Message 60 of 60
david.lau
You must change your language to USA English.  Then 'delete' Maya.
All the instructions are noted here:
http://upandready.typepad.com/up_and_ready/2013/10/maya-2014-on-mac-109-mavericks-error-110-when-act...
David Lau
Administrator Productivity
