first I would like to describe my situation. I have purchased Autocad LT 2012 and installed it on my notebook without problems. On my desktop I continued using my Autocad 2011 version.
Now I am getting new desktop machine and would like to use there 2012 version too. Installation was OK, but when I try to activate the product using my Serial Number, I always get error "The serial number you entered is not valid"
What could have gone wrong? I heard that it is possible to use 2012 version on two machines under condition that program is not running on both at the same time - which it definitely isnt.
I also checked my serial number using instructions found here - it shows that my SN is correct ans I dont have higher version of product.
Then why the system refuses to accept it?
Thank you for yours suggestions
Darina
Hi Darina,
If you could send me via Private Message (click on my joane.bonghanoy profile name and then “Send this user a private message”) your 2011 and 2012 Serial Number, I would gladly assist you on this issue.
