Installation & Licensing
Member
0 Kudos
Post 11 of 24
Re: Unable to Access Subscription Center- Error #111
04-03-2014 08:54 AM in reply to: JODIEROBERTSON4839
I too am having this problem. It just happened when Autodesk started the new subscription services. Can anybody help me with this?
221 Kudos
Post 12 of 24
04-03-2014 09:18 AM in reply to: DeanRiley4741
Hi Dean,
I have just looked up your account by your email address. You are receiving the the #111 Error because you are not listed on this contract as a named user. If you would like access to the Subscription Center, please contact your Contract Manager and ask them to add you.
How to create a named user and set user permissions in User Management
If you have any other questions please let me know or have your Contract Manager submit a request. Thank you!
Jessica Thrasher
Valued Contributor
0 Kudos
Post 13 of 24
04-13-2014 02:05 PM in reply to: jessica.t
I am now getting this error. I am the software coordinator. I have requested support twice, but have yet to receive a reply. Can you please check and see if you can fix it? Thanks, Patrick
Customer Service
71 Kudos
Post 14 of 24
04-13-2014 07:17 PM in reply to: PatrickManson
Hi Patrick,
Appologies for the error and any inconvenience this has caused you in any way.
I saw the case you sumbitted under Case # 09449026. I will reply to you from the said case
Joane Bonghanoy
Valued Contributor
0 Kudos
Post 15 of 24
04-13-2014 09:19 PM in reply to: DeanRiley4741
Hi Joane, have you made any progress on this support request? Cheers, patrick
Customer Service
71 Kudos
Post 16 of 24
04-14-2014 12:42 AM in reply to: PatrickManson
Hi Patrick,
I emailed you via the case I mentioned on my reply above and called your office as well but was told you're currently unavailable to answer the phone.
I saw 2 profiles under your name and I wasn't sure which is correct and which of the 2 you wanted to keep. I included the details on my reply, upon your reply to that email I will then make the appropriate action.
Joane Bonghanoy
New Member
0 Kudos
Post 17 of 24
Re: Unable to Access Subscription Center- user account invalid
04-14-2014 10:34 AM in reply to: JODIEROBERTSON4839
hi,
I also am having problems logging into mu subscription centre. However... I get the following message...
User account no longer valid.
Autodesk Subscription has determined that your user account is no longer valid.
The most likely reason for this is that the contract manager or software coordinator for these contract(s) removed your user account. Please contact that person for more information.
Can somebody please help me?
221 Kudos
Post 18 of 24
04-14-2014 10:58 AM in reply to: JK-Tekenburo
Hi JK-Tekenburo and welcome to the Autodesk Community!
To successfully access the Subscription Center, please be sure that you are using your Contract Manager user ID and password. I looked at your account and see there are two IDs, so this is very important. If you are sure you are using the correct one and the error persists, please contact our customer service team directly through our Contact Us page. Select your issue, topic, and then "I still need help" to pull up the associated chat options.
Please also see our Autodesk Accounts Sign In FAQ for further details. If you have further questions please let us know. Thank you!
Jessica Thrasher
New Member
0 Kudos
Post 19 of 24
Error 110
04-14-2014 11:40 AM in reply to: jessica.t
I am getting quite a few errors trying to get Maya 2014 to run on my computer. I took a webshot of the error reports.
221 Kudos
Post 20 of 24
Re: Error 110
04-14-2014 12:06 PM in reply to: tspera15
Hi @tspera15 !
Please see the following solutions for this error:
Up and Ready Blog post
Solution One
Solution Two
Please let me know if you need further assistance or have any other questions. Thanks!
Jessica Thrasher
