Installation & Licensing
Un-installing Autodesk FBX Plug-in 2012.0 - 3ds Max Design
4 REPLIES 4
1445 Views, 4 Replies
I was wondering if there is a command line switch for quiet or passive un-installation.  I have tried all the typical switchs e.g: /q, /qn, /passive, /silent
C:\Program Files\Autodesk\FBX\FBXPlugins\2012.0\3ds Max Design 2012 64-bit\Uninstall.exe
David
4 REPLIES 4
hashim.mundol
Please try
http://area.autodesk.com/forum/autodesk-fbx/fbx-plug-ins-import-export-discussions/silent-install---...
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Autodesk, Inc.
hashim.mundol
Also did you try /s ?
Hashim Mundol
Autodesk, Inc.
i couldn't remember trying /s so I tried again and it gives me the gui to step through it.  I as tried /S too and it looks like the .exe starts and quits.  So no luck in this.
Smiley Indifferent
Hi
I am also trying to use the uninstaller to remove the FBX plug-in silently.  I have looked through the Nullsoft documentation and the switch they say should work is /S:-
http://nsis.sourceforge.net/Docs/Chapter3.html#3.2.1
When I run "C:\Program Files\Autodesk\FBX\FBXPlugins\2012.0\3ds Max 2012 64-bit\Uninstall.exe" /S I cannot even see the process start in the task manager.
Hashim can you test this yourself and make sure this is not a bug with the 2012 unistaller?
Administrator Productivity
