Installation & Licensing
two suites in pc
4 REPLIES 4
giovannybm
249 Views, 4 Replies
two suites in pc
is possible install two suit in a same computer? autodesk product design suite + fabric  design suite in a same computer
4 REPLIES 4
DarrenP
in reply to: giovannybm
yea as long as you have a serial number for both products
there will be an overlap of products
DarrenP
giovannybm
in reply to: DarrenP
i trying use trial version but for example inventor professional has different in borh suites and only can install one
DarrenP
yea you only install inventor 2014 once from whatever suite your installing it from
its not going to install inventor twice on the same machine
DarrenP
inchul.lee
Hi giovannybm,
As DarrenP already pointed out, only 1 Inventor product can be installed. So, it will be either Inventor 2014 or Inventor Professional 2014 depending on the edtions of Suites you have.
For example,
Product Design Suite Standard 2014 includes Inventor 2014
Factory Design Suite Ultimate 2014 includes Inventor Professional 2014
If you have both of the above, then you can choose to install either edition of Inventor 2014.
I've marked DarrenP's post as a solution of this post.
Inchul Lee
Administrator Productivity
