i get two errors and i can't open AutoCAD 2011 Electrical nor can i uninstall. When i try to open i get the following "adui18res.dll not found" and when i try to uninstall this appears "AcadeUIRes.dll is not found. I was able to reinstall and fix the error according to AutoCAD however, i continue to get these two errors. Running Windows 7 64bit SP1.
Can anyone shed light on how to correc this?
Sounds like a re install might be needed. If the installer is not letting you perform the un-install. Please use the microsoft install cleanup fixit tool at the below link
http://support.microsoft.com/mats/Program_Install_and_Uninstall
1.) Click the "Run now" Button in the Fix-it box
2.) Accept the License Agreement
3.) Choose the option "Detect Problems and let me select fixes to apply"
4.) Select "Uninstalling"
5.) When the list of installed programs populates, select the one from the list you are unable to Re-install and then click next and yes
6.) When the tool completes There may be remnants left so please delete the directory where the product was installed (C:\Program Files\Autodesk\AutoCAD 2011 for example)
Once this is complete you should be able to re-install normally.
