Installation & Licensing
Tsplines student activation
2 REPLIES 2
isardinas
1656 Views, 2 Replies
I am having problems activatint my tsplines plugin.  i downloaded and intalled it but did not get an activation code.  i did get a serial number and product key but i am not sure where to use these to activate Tsplines as it is a plug in for Rhino and not a stand alon program.
Thank you in advance for any help you can give me
I Sardinas
2 REPLIES 2
arlinpega.bibat
in reply to: isardinas
Hi isardinas:
I tried installing it on my machine and it didn't ask for a serial number as well. We're you able to run it from your end? An alternative would be to go to this link: www.tsplines.com/forum  where you can ask and get answers from other T-Splines users. Meanwhile, I will check further as well with the appropriate channel for clarification. Smiley Happy
Best Regards,
Arlin Bibat
Hi isardinas,
We recently switched our licensing of T-Splines to use standard Autodesk licensing. We had a few hiccups as we changed this over, and it sounds like you have the old installer, with the new license key. If you return to your Autodesk account, you should now have the updated download, 3.5, which is about 100 MB.
With this new download, your key will work.
Let me know if you have further questions, and I can get you a direct download link if necessary.
Matt
Administrator Productivity
