Installation & Licensing
3 Kudos
Post 1 of 7
Trying to reinstall Revit 2014, says it's already installed and won't let me.
3225 Views, 6 Replies
04-29-2013 02:43 PM
I was having trouble installing all of the Autodesk programs on the flash drive.  They all failed installation, except Revit left an icon that didn't do anything.
I looked at the requirements and realized I needed the latest version of Internet Explorer.  So I installed that, and then reinstalled several of my most used AutoDesk programs, and they all worked, exept Revit.
I went through the add/remove programs box, the registry, and the program files folder and deleted everything with Revit 2014.  Restarted the computer many times.  But the setup.exe dialog box still says it's on my computer and won't let me reinstall or repair it.  What else can I do??
Thanks!
Fixed it!  I found an Uninstall Tool in the AutoDesk folder in the Start Menu.  I used that and it cleared Revit so I could install it again. :catvery-happy:
3 Kudos
Post 2 of 7
Re: Trying to reinstall Revit 2014, says it's already installed and won't let me
04-30-2013 09:11 AM in reply to: lilkitkat80
Member
0 Kudos
Post 3 of 7
10-31-2013 10:03 AM in reply to: lilkitkat80
THANK GOD YOU FOUND THE SOLUTION YOURSELF and now I faced the same problem and you saved my life !
282 Kudos
Post 4 of 7
10-31-2013 01:19 PM in reply to: renny_chan22
I wanted to add that we also recommend running Microsoft Fix-it if you happen to find yourself in a situation where Windows will not let you install as the OS thinks the software is already present.
Philip Schmelzer
New Member
0 Kudos
Post 5 of 7
12-12-2013 01:15 PM in reply to: lilkitkat80
You just saved my computer from being thrown through the window. I wish I read this 2 hours ago.
New Member
0 Kudos
Post 6 of 7
12-12-2013 08:21 PM in reply to: lilkitkat80
OMG, YOU SAVED MY LIFE, THANK YOU SOOOOOOOOOOOOOOO MUCH!!!! I ALMOST REINSTALLED MY WHOLE SYSTEM...
Active Member
1 Kudo
Post 7 of 7
10-30-2014 01:54 PM in reply to: lilkitkat80
Thanks so much for posting the answer. I ran into thsi today and you ahve given me the direction to go.
