My name is Yu,
while i trying to download and install the trial version it keeps failing on me at the same spot.
Here is the ending part of the error script:
"2014/2/10:05:30:53 yu YUCHEN Install Autodesk® Material Library 2014 - Base Image Library Succeeded
2014/2/10:05:30:53 yu YUCHEN Download Play CMILM http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/CMILM.tar...
2014/2/10:05:37:04 yu YUCHEN Download Aborted CMILM http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/CMILM.tar...
2014/2/10:05:37:04 yu YUCHEN Install Autodesk® Material Library 2014 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2014/2/10:05:37:09 yu YUCHEN Rollback Autodesk® Material Library 2014 - Base Image Library Succeeded
2014/2/10:05:37:20 yu YUCHEN Rollback Autodesk® Material Library 2014 Succeeded
2014/2/10:05:37:20 yu YUCHEN Rollback DirectX® Runtime Failed Failure is ignored, Result=1619"
Please help me with this .
Thank You
Do you click on the Install Now button? Have you tried clicking on the Browser Download option to download the app first and then install? You should see a pull down arrow in the button with that as one of the choices.
