for showing cad files we embed the trueview plug-in in a IE frame in Java software. Purpose is for customers that downloaded the software to view files from within the Java software. When the file to show has been created by AutoDesk, there is no problem in viewing the file.
When the file is created by other software it hangs.
Workaround:
open the file directly in DWG Trueview and then I get a message that mentions that the file was not created in AutoDesk software. I confirm that I want to open the file and that TrueView should do this for all the files that are not created through AutoDesk software. I can understand this behaviour, however would it be possible to pass a parameter when installing TrueView so it won't need the confirmation?
Thanks in advance,
Gildon
