Installation & Licensing
467 Views, 1 Reply
True View
I get error box
"LoadLibrary failed with error 126: The specified module could not be found"
Running Windows 8 in Desktop Mode.
AutoDesk Software installed ADT 2007
All I want to do in convert a modern DWG back to version 2007.  I dont need all the bloat of TrueView.  I would appreciate either help fixing the current install or if there is a light weight alternative that can do the conversions simply ( i.e. no viewer required )
Thanks in advance,
-E
1 REPLY 1
pendean
DTV is it if you only want an Autodesk solution: there are others out there is you want lighter faster etc., but I don't think they are free. Explore in your favorite webbrowser.
Your issue has a solution in the DTV dedicated forum. hope it helps: http://forums.autodesk.com/t5/DWG-TrueView/LoadLibrary-failed-with-error-126-The-specified-module-co...
Administrator Productivity
