Installation & Licensing
New Member
red106
Message 1 of 6 (5,079 Views)
True View installation says 'system cannot open the device or file' or find path
5079 Views, 5 Replies
04-20-2011 10:48 AM
New Member
astuartmills
Message 2 of 6 (4,979 Views)
Re: True View installation says 'system cannot open the device or file' or find
05-10-2011 07:55 PM in reply to: red106
I am having the same issue and then it cannot locate the dwgviewr.msi... any ideas?
Active Member
asimasko
Message 3 of 6 (4,950 Views)
05-13-2011 12:41 AM in reply to: astuartmills
Same prolem here.  Earlier version worked.  When opening drawing in Design Review it said needed latest version of DWG TrueView.  Downloaded from Autdesk web site and now stuck.  Looks like a 32 bit version was downloaded.  Can't find 64-bit version although have seen references to one on other discussion groups.
My system:  Windows 7, 64bit
Active Member
asimasko
Message 4 of 6 (4,946 Views)
05-13-2011 01:32 AM in reply to: red106
Did a little searching on the Autodesk web site.  Go here
http://images.autodesk.com/adsk/files/adr2012_install_guide.htm#InstallADRManual
and follow directions for Manual Installation using the Bootstrap Installer (click on link)
Takes some time but it worked for me.  I guess it gets around the downloaded version not having all the installation files compressed into it (the missing dwgviewr.msi file).  Come on Autodesk, you can do better than this.
Good Luck
Andy
New Member
astuartmills
Message 5 of 6 (4,920 Views)
05-19-2011 10:24 AM in reply to: red106
I realized I was trying to install the 32 bit version on my 64 bit system.  I found the 64 bit verision here http://usa.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=9555277 and downloaded it.  It works now.  I appreciate everyone's feedback.
Moderator
Discussion_Admin
Message 6 of 6 (4,909 Views)
05-20-2011 11:46 AM in reply to: red106
If you are posting using IE 9 and the body of your post is blank. Please see the following thread in the Feedback & Questions about the Discussion Groups forum.
http://forums.autodesk.com/t5/Feedback-Questions-about-the/Blank-Posts-Known-IE9-issue/m-p/2962896/m...
Thanks for using the forums
Discussion_Admin
