Installation & Licensing
True View installation says 'system cannot open the device or file' or find path
5 REPLIES 5
5654 Views, 5 Replies
5 REPLIES 5
I am having the same issue and then it cannot locate the dwgviewr.msi... any ideas?
asimasko
Same prolem here.  Earlier version worked.  When opening drawing in Design Review it said needed latest version of DWG TrueView.  Downloaded from Autdesk web site and now stuck.  Looks like a 32 bit version was downloaded.  Can't find 64-bit version although have seen references to one on other discussion groups.
My system:  Windows 7, 64bit
asimasko
Did a little searching on the Autodesk web site.  Go here
http://images.autodesk.com/adsk/files/adr2012_install_guide.htm#InstallADRManual
and follow directions for Manual Installation using the Bootstrap Installer (click on link)
Takes some time but it worked for me.  I guess it gets around the downloaded version not having all the installation files compressed into it (the missing dwgviewr.msi file).  Come on Autodesk, you can do better than this.
Good Luck
Andy
I realized I was trying to install the 32 bit version on my 64 bit system.  I found the 64 bit verision here http://usa.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=9555277 and downloaded it.  It works now.  I appreciate everyone's feedback.
Discussion_Admin
If you are posting using IE 9 and the body of your post is blank. Please see the following thread in the Feedback & Questions about the Discussion Groups forum.
http://forums.autodesk.com/t5/Feedback-Questions-about-the/Blank-Posts-Known-IE9-issue/m-p/2962896/m...
Thanks for using the forums
Discussion_Admin
Administrator Productivity
