Installation & Licensing
Troubles installing Product Design Suite Premium 2012
5 REPLIES 5
sdolinsky
701 Views, 5 Replies
When I start the set up (Setup.exe) the initialization begins and I immediately get an error which reads "The system cannot open the device or file specified",,,please let me know if you may have a proposed solution.
Best Regards,
Scott Dolinsky
5 REPLIES 5
hashim.mundol
in reply to: sdolinsky
Please post all the log files from the %temp% folder.(as zipped)
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Autodesk, Inc.
sdolinsky
The "Can't Open" folder consists of the 2 files that the Setup cannot open.
hashim.mundol
Please try to copy the media content locally to the disk and then try to run the setup
Hashim Mundol
Autodesk, Inc.
sdolinsky
in reply to: hashim.mundol
I have already tried that, and no it does not work. The same errors pop up.
TravisNave
There are a couple of things that can cause this:
1.  You are installing from a Terminal Server, mapped drive, or have invalid mapped drives and paths on your computer.
2.  Your hard drive is using the Encrypted File System (EFS) and the installer doesn't have access to the locations it needs.  Turn off file encryption.
3.  Your Windows Installer needs updated.  Get the latest version from Microsoft.
4.  You don't have permissions to write to your %TEMP% location.  Check your privileges as well as those listed in the temp folder for your profile.
Autodesk Forums:
Administrator Productivity
