I am having trouble with CFDesign. The license is based on a server and it seems it is not mapped to the software installed on my PC. I get the attached error messages. I have also attached the folder which contains our licenses. Please can someone help!
-5 error means the product doesn't exist. I suspect you need to get a new 2013 license file and upgrade your license manager to use it.
For a Quick-Start Guide on configuring the Autodesk License Manager, please see my post for further information:
http://forums.autodesk.com/t5/Installation-Licensing/Quick-Start-Guide-for-Configuring-LMTOOLS/m-p/3...
Thanks for this info. I have noticed that my 'Ethernet Address' does not match the .LIC file. I guess this is because the license is 2012 and I have 2013. Is there anyway to gain a 2013 license? I was told by our rep that you can change the license to work with 2013?
Your rep was incorrect on all points.
You need a brand new license file for 2013. If it is under Subscription, it will be backwards compatible. If not, then you can only run the latest version that you have registered.
You can get a new license file thru your Reseller or by using the online method: http://register.autodesk.com
Good Luck!
Thanks for the link. I have stupidly exhausted my license generation attempts by not know exactly what I was doing. I know understand I need to generate 3x license files based on 3x serial no.s for DSE/PARASOLID/SOLVER. Would someone be kind enough to reset my licenses?
Your reseller would be your best bet for a quick fix on this.
