Installation & Licensing
trouble with autocad LT 2010 and windows 7
5 REPLIES 5
giorgiofrighi
438 Views, 5 Replies
Hi from Italy, this is my first message! sorry for my english...
I have to change some winxp workstations in my office; I've installed autocad LT 2010 on a new window 7 pc.
Launching the application, i receive the message "the application has failed to start because its side-by-side configuration is incorrect. Please see the application event log for more detail or use the sxstrace command for further information".
I've already removed and re-installed microsoft visual c++ package.
Some other details:
Software: Autocad LT2010 vers. 18.0.55.0
Pc: windows 7 pro 64 bit SP1, 4GB ram, video card Nvidia GE force GT630
Anybody can help me?
thanks in advance
Giorgio Frighi
5 REPLIES 5
TravisNave
in reply to: giorgiofrighi
Typically, this is a .NET Framework issue.  You might consider the .NET Framework cleanup utility.
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
But first, have you at least tried updating AutoCAD LT to the latest service pack 2?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15073321&linkID=9240818
Good Luck!
Autodesk Forums:
dembkod
giorgiofrighi,
Hello. Did you uninstall ALL the Microsoft C++ entries? Most machines have multiples. I would uninstall the program and then all C++ and then uninstall the NET on the system and then try to install the program. It should install the C++ versions it is in need of.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14095878&linkID=9241177
Thank you for taking part in our community!
David Dembkoski
Hello. Thanks for you support.
I've tried all the suggestions: removed and re-installed C++ entries, .NET entry (also using cleanup utility) and updated autocad LT to SP2... but still have the problem.
dembkod
giorgiofrighi,
Hello. Sounds like a really messy install. Plus, Autocad LT 2010 was not built for Win 7.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15460215&linkID=9240817#section12
The fastest solution is to reinstall the OS, run all the system updates and then install. This is the quickest guarantee of a clean slate. If you are failing after this it usually means a hardware problem for a user. Nothing I see here makes me think you are having a hardware issue of any sort- you are likely dealing with leftover registry keys and such.
If you aren’t ready to format and start over, I would try this:
-Uninstall ALL Autodesk Software
-Run the MS fixit utility to uninstall any remaining Autodesk software that the tool can still see:
            http://support.microsoft.com/mats/Program_Install_and_Uninstall\
-Delete any Remaining Autodesk folders:
            C:\Program Files\Autodesk\
C:\ProgramData\Autodesk\
C:\Users\All Users\
C:\Users\**YOUR USERID**\AppData\Roaming\Autodesk\
C:\Users\**YOUR USERID**\AppData\Local\Autodesk\
-Delete the tsf.data files. They will resemble this ADSKFLEX_NUMBERS_TSF.data
C:\ProgramData\FLEXnet
-Delete the C:\Program Files\Common Files\Macrovision Shared\ folder
-Delete the C:\Program Files\Common Files\Autodesk Shared\ folder
-Uninstall the C++ entries
-Uninstall NET framework
-Reboot the machine
-Install the programs and test.
This is about as much as I would try before a reformat.
David Dembkoski
Hello, sorry for the delay, i've had to do some other jobs.
I don't want to format and reinstall, so I tried the other ways you suggest, but still have the same message.
I think I will soon give up and install it in xp mode...
anyway, thank you very much
Administrator Productivity
