Installation & Licensing
Trouble trying to install Civil 3d 2012
1 REPLY 1
kyrazi1
434 Views, 1 Reply
I’ve having trouble installing a program for one of my classes and need to see if you can offer some advice. The program is AutoCAD Civil 3d from Autodesk. I’m fairly certain that I have all the proper requirements installed and ready to go as well as having my virus software disabled. Every time I try and download it I receive an error and it gives me the syntax. I’m not really sure if it helps or not but I know you understand this stuff a lot better than me.
2012/3/15:12:13:03          Justin Kyriazi      JUSTINKYRIAZI  === Setup started on JUSTINKYRIAZI by Justin Kyriazi ===
2012/3/15:12:13:03          Justin Kyriazi      JUSTINKYRIAZI  Launch
2012/3/15:12:14:09          Justin Kyriazi      JUSTINKYRIAZI  PageOpen           LaunchDialog
2012/3/15:12:16:00          Justin Kyriazi      JUSTINKYRIAZI  PageOpen           LicenseDialog
2012/3/15:12:16:08          Justin Kyriazi      JUSTINKYRIAZI  PageOpen           ProductInfoDialog
2012/3/15:12:16:44          Justin Kyriazi      JUSTINKYRIAZI  PageOpen           ProductSelectionDialog2
2012/3/15:12:18:00          Justin Kyriazi      JUSTINKYRIAZI  PageOpen           ProductInfoDialog
2012/3/15:12:18:01          Justin Kyriazi      JUSTINKYRIAZI  PageOpen           ProductSelectionDialog2
2012/3/15:12:18:09          Justin Kyriazi      JUSTINKYRIAZI  PageOpen           FullProgressDialog
2012/3/15:12:18:09          Justin Kyriazi      JUSTINKYRIAZI  Installing DirectX Runtime: C:\autodesk\AutoCAD_Civil3D_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/3/15:12:19:22          Justin Kyriazi      JUSTINKYRIAZI  Install    DirectX Runtime               Succeeded
2012/3/15:12:19:22          Justin Kyriazi      JUSTINKYRIAZI  Installing Microsoft Visual Basic Power Packs 3.0: C:\autodesk\AutoCAD_Civil3D_2012_English_Win_64bit\3rdParty\VBPowerPacks\VisualBasicPowerPacks3Setup.exe /q /l C:\Users\JUSTIN~1\AppData\Local\Temp\VisualBasicPowerPacks3Setup.log
2012/3/15:12:19:32          Justin Kyriazi      JUSTINKYRIAZI  Install    Microsoft Visual Basic Power Packs 3.0   Succeeded
2012/3/15:12:19:33          Justin Kyriazi      JUSTINKYRIAZI  Installing AutoCAD Civil 3D 2012:  TRANSFORMS="C:\autodesk\AutoCAD_Civil3D_2012_English_Win_64bit\x64\en-us\C3D\C3D.mst;C:\Users\JUSTIN~1\AppData\Local\Temp\_AID98C.tmp\x64\C3D\C3D-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\autodesk\AutoCAD_Civil3D_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD Civil 3D 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/3/15:12:20:16         Justin Kyriazi      JUSTINKYRIAZI  Install    AutoCAD Civil 3D 2012    Failed    Installation aborted, Result=1603
2012/3/15:12:20:16          Justin Kyriazi      JUSTINKYRIAZI  Rollback               Microsoft Visual Basic Power Packs 3.0   Failed                Failure is ignored, Result=1619
2012/3/15:12:20:16          Justin Kyriazi      JUSTINKYRIAZI  Rollback               DirectX Runtime               Failed    Failure is ignored, Result=1619
If you can help me in any way, it would be greatly appreciated.
Best Regards,
Justin Kyriazi
1 REPLY 1
TravisNave
in reply to: kyrazi1
Justin,
You might need to zip and attach the other installation log in your %TEMP% file.  It will be larger and have more information about your failure.  Autodesk should be able to help you with that once they can determine the reason for the 1603 in the installation log file.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
