I’ve having trouble installing a program for one of my classes and need to see if you can offer some advice. The program is AutoCAD Civil 3d from Autodesk. I’m fairly certain that I have all the proper requirements installed and ready to go as well as having my virus software disabled. Every time I try and download it I receive an error and it gives me the syntax. I’m not really sure if it helps or not but I know you understand this stuff a lot better than me.
2012/3/15:12:13:03 Justin Kyriazi JUSTINKYRIAZI === Setup started on JUSTINKYRIAZI by Justin Kyriazi ===
2012/3/15:12:13:03 Justin Kyriazi JUSTINKYRIAZI Launch
2012/3/15:12:14:09 Justin Kyriazi JUSTINKYRIAZI PageOpen LaunchDialog
2012/3/15:12:16:00 Justin Kyriazi JUSTINKYRIAZI PageOpen LicenseDialog
2012/3/15:12:16:08 Justin Kyriazi JUSTINKYRIAZI PageOpen ProductInfoDialog
2012/3/15:12:16:44 Justin Kyriazi JUSTINKYRIAZI PageOpen ProductSelectionDialog2
2012/3/15:12:18:00 Justin Kyriazi JUSTINKYRIAZI PageOpen ProductInfoDialog
2012/3/15:12:18:01 Justin Kyriazi JUSTINKYRIAZI PageOpen ProductSelectionDialog2
2012/3/15:12:18:09 Justin Kyriazi JUSTINKYRIAZI PageOpen FullProgressDialog
2012/3/15:12:18:09 Justin Kyriazi JUSTINKYRIAZI Installing DirectX Runtime: C:\autodesk\AutoCAD_Civil3D_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/3/15:12:19:22 Justin Kyriazi JUSTINKYRIAZI Install DirectX Runtime Succeeded
2012/3/15:12:19:22 Justin Kyriazi JUSTINKYRIAZI Installing Microsoft Visual Basic Power Packs 3.0: C:\autodesk\AutoCAD_Civil3D_2012_English_Win_64bit\3rdParty\VBPowerPacks\VisualBasicPowerPacks3Setup.exe /q /l C:\Users\JUSTIN~1\AppData\Local\Temp\VisualBasicPowerPacks3Setup.log
2012/3/15:12:19:32 Justin Kyriazi JUSTINKYRIAZI Install Microsoft Visual Basic Power Packs 3.0 Succeeded
2012/3/15:12:19:33 Justin Kyriazi JUSTINKYRIAZI Installing AutoCAD Civil 3D 2012: TRANSFORMS="C:\autodesk\AutoCAD_Civil3D_2012_English_Win_64bit\x64\en-us\C3D\C3D.mst;C:\Users\JUSTIN~1\AppData\Local\Temp\_AID98C.tmp\x64\C3D\C3D-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\autodesk\AutoCAD_Civil3D_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD Civil 3D 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/3/15:12:20:16 Justin Kyriazi JUSTINKYRIAZI Install AutoCAD Civil 3D 2012 Failed Installation aborted, Result=1603
2012/3/15:12:20:16 Justin Kyriazi JUSTINKYRIAZI Rollback Microsoft Visual Basic Power Packs 3.0 Failed Failure is ignored, Result=1619
2012/3/15:12:20:16 Justin Kyriazi JUSTINKYRIAZI Rollback DirectX Runtime Failed Failure is ignored, Result=1619
If you can help me in any way, it would be greatly appreciated.
Best Regards,
Justin Kyriazi
Justin,
You might need to zip and attach the other installation log in your %TEMP% file. It will be larger and have more information about your failure. Autodesk should be able to help you with that once they can determine the reason for the 1603 in the installation log file.
