Sometime ago I went in trouble when unistalling Autocad 2012 architecture. Since then, when I reinstalled it, the Inventor Fusion option always shows as already installed, which is not true. I don't know how to fix it. I already tried to fix using MS Msi Cleanup Utility, but no "inventor fusion" appears there. Add/or remove program doesn't show inventor also. CCleaner doesn't help, or any other register cleaner (I think iobit toolbox register cleaner was causing some damage on Acad, because I had some problems to open/save as/import files, after used it)
If I try to uninstall/reinstall using directly the inventor fusion package from acad Dvd (x64/inventor fusion folder), it shows the message below:
Erro ao aplicar transformações. Verifique se os caminhos de transformação especificados são válidos.
in english: "Error applying transforms. Verify that the specified transform paths are valid."
I'm using Windows 7 Premium x64
,=== Verbose logging started: 06/08/2011 23:50:32 Build type: SHIP UNICODE 5.00.7601.00 Calling process: C:\Windows\system32\msiexec.exe === MSI (c) (E0:44) [23:50:32:306]: Font created. Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg MSI (c) (E0:44) [23:50:32:306]: Font created. Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg MSI (c) (E0:04) [23:50:32:319]: Resetting cached policy values MSI (c) (E0:04) [23:50:32:319]: Machine policy value 'Debug' is 0 MSI (c) (E0:04) [23:50:32:319]: ******* RunEngine: ******* Product: j:\x64\inventorfusion\inventorfusion.msi ******* Action: ******* CommandLine: ********** MSI (c) (E0:04) [23:50:32:357]: Machine policy value 'DisableUserInstalls' is 0 MSI (c) (E0:04) [23:50:32:385]: Warning: Local cached package 'C:\Windows\Installer\14c0f5.msi' is missing. MSI (c) (E0:04) [23:50:32:393]: User policy value 'SearchOrder' is 'nmu' MSI (c) (E0:04) [23:50:32:393]: User policy value 'DisableMedia' is 0 MSI (c) (E0:04) [23:50:32:393]: Machine policy value 'AllowLockdownMedia' is 1 MSI (c) (E0:04) [23:50:32:393]: SOURCEMGMT: Looking for sourcelist for product {FFF5619F-6669-4EC5-A85E-9994F70A9E5D} MSI (c) (E0:04) [23:50:32:394]: SOURCEMGMT: Adding {FFF5619F-6669-4EC5-A85E-9994F70A9E5D}; to potential sourcelist list (pcode;disk;relpath). MSI (c) (E0:04) [23:50:32:402]: SOURCEMGMT: Now checking product {FFF5619F-6669-4EC5-A85E-9994F70A9E5D} MSI (c) (E0:04) [23:50:32:402]: SOURCEMGMT: Attempting to use LastUsedSource from source list. MSI (c) (E0:04) [23:50:32:414]: SOURCEMGMT: Trying media source J:\x64\InventorFusion\. MSI (c) (E0:04) [23:50:32:491]: Cloaking enabled. MSI (c) (E0:04) [23:50:32:491]: Attempting to enable all disabled privileges before calling Install on Server MSI (c) (E0:04) [23:50:32:508]: Connected to service. MSI (c) (E0:04) [23:50:32:511]: SOURCEMGMT: Resolved source to: 'J:\x64\InventorFusion\' MSI (c) (E0:04) [23:50:32:552]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'j:\x64\inventorfusion\inventorfusion.msi' against software restriction policy MSI (c) (E0:04) [23:50:32:578]: Note: 1: 2262 2: DigitalSignature 3: -2147287038 MSI (c) (E0:04) [23:50:32:578]: SOFTWARE RESTRICTION POLICY: j:\x64\inventorfusion\inventorfusion.msi is not digitally signed MSI (c) (E0:04) [23:50:32:581]: SOFTWARE RESTRICTION POLICY: j:\x64\inventorfusion\inventorfusion.msi is permitted to run at the 'unrestricted' authorization level. MSI (c) (E0:04) [23:50:32:585]: Cloaking enabled. MSI (c) (E0:04) [23:50:32:585]: Attempting to enable all disabled privileges before calling Install on Server MSI (c) (E0:04) [23:50:32:585]: End dialog not enabled MSI (c) (E0:04) [23:50:32:585]: Original package ==> J:\x64\InventorFusion\InventorFusion.msi MSI (c) (E0:04) [23:50:32:585]: Package we're running from ==> C:\Users\andre\AppData\Local\Temp\db6654.msi MSI (c) (E0:04) [23:50:32:591]: APPCOMPAT: Uninstall Flags override found. MSI (c) (E0:04) [23:50:32:591]: APPCOMPAT: Uninstall VersionNT override found. MSI (c) (E0:04) [23:50:32:591]: APPCOMPAT: Uninstall ServicePackLevel override found. MSI (c) (E0:04) [23:50:32:598]: APPCOMPAT: looking for appcompat database entry with ProductCode '{FFF5619F-6669-4EC5-A85E-9994F70A9E5D}'. MSI (c) (E0:04) [23:50:32:605]: APPCOMPAT: no matching ProductCode found in database. MSI (c) (E0:04) [23:50:32:621]: MSCOREE not loaded loading copy from system32 MSI (c) (E0:04) [23:50:32:639]: Machine policy value 'DisablePatch' is 0 MSI (c) (E0:04) [23:50:32:639]: Machine policy value 'AllowLockdownPatch' is 0 MSI (c) (E0:04) [23:50:32:639]: Machine policy value 'DisableLUAPatching' is 0 MSI (c) (E0:04) [23:50:32:639]: Machine policy value 'DisableFlyWeightPatching' is 0 MSI (c) (E0:04) [23:50:32:641]: Looking for file transform: C:\Windows\Installer\{FFF5619F-6669-4EC5-A85E-9994F70A9E5D}\InventorFusion.mst MSI (c) (E0:04) [23:50:32:642]: Unable to create a temp copy of transform 'C:\Windows\Installer\{FFF5619F-6669-4EC5-A85E-9994F70A9E5D}\InventorFusion.mst'. MSI (c) (E0:04) [23:50:32:642]: Note: 1: 2203 2: C:\Windows\Installer\{FFF5619F-6669-4EC5-A85E-9994F70A9E5D}\InventorFusion.mst 3: -2147287037 MSI (c) (E0:04) [23:50:32:642]: Couldn't find cached transform C:\Windows\Installer\{FFF5619F-6669-4EC5-A85E-9994F70A9E5D}\InventorFusion.mst. Looking for it at the source. MSI (c) (E0:04) [23:50:32:642]: Resolving source. MSI (c) (E0:04) [23:50:32:642]: Resolving source to launched-from source. MSI (c) (E0:04) [23:50:32:642]: Setting launched-from source as last-used. MSI (c) (E0:04) [23:50:32:642]: SOURCEDIR ==> J:\x64\InventorFusion\ MSI (c) (E0:04) [23:50:32:642]: SOURCEDIR product ==> {FFF5619F-6669-4EC5-A85E-9994F70A9E5D} MSI (c) (E0:04) [23:50:32:642]: Looking for file transform: C:\Windows\Installer\{FFF5619F-6669-4EC5-A85E-9994F70A9E5D}\InventorFusion.mst MSI (c) (E0:04) [23:50:32:642]: Unable to create a temp copy of transform 'C:\Windows\Installer\{FFF5619F-6669-4EC5-A85E-9994F70A9E5D}\InventorFusion.mst'. MSI (c) (E0:04) [23:50:32:643]: Note: 1: 2203 2: C:\Windows\Installer\{FFF5619F-6669-4EC5-A85E-9994F70A9E5D}\InventorFusion.mst 3: -2147287037 MSI (c) (E0:04) [23:50:32:643]: Couldn't find cached transform C:\Windows\Installer\{FFF5619F-6669-4EC5-A85E-9994F70A9E5D}\InventorFusion.mst. Looking for it at the source. MSI (c) (E0:04) [23:50:32:643]: Looking for file transform: J:\x64\InventorFusion\InventorFusion.mst MSI (c) (E0:04) [23:50:32:643]: Unable to create a temp copy of transform 'J:\x64\InventorFusion\InventorFusion.mst'. MSI (c) (E0:04) [23:50:32:643]: Note: 1: 2203 2: J:\x64\InventorFusion\InventorFusion.mst 3: -2147287038 DEBUG: Error 2203: Database: J:\x64\InventorFusion\InventorFusion.mst. Cannot open database file. System error -2147287038 1: 2203 2: J:\x64\InventorFusion\InventorFusion.mst 3: -2147287038 Erro ao aplicar plataformas. Verifique se os caminhos de transformação especificados são válidos. J:\x64\InventorFusion\InventorFusion.mst MSI (c) (E0:04) [23:50:32:650]: Note: 1: 1708 MSI (c) (E0:04) [23:50:32:650]: Product: Autodesk Inventor Fusion 2012 -- Installation failed. MSI (c) (E0:04) [23:50:32:651]: Windows Installer installed the product. Product Name: Autodesk Inventor Fusion 2012. Product Version: 1.0.0.79. Product Language: 1033. Manufacturer: Autodesk, Inc.. Installation success or error status: 1624. MSI (c) (E0:04) [23:50:32:655]: MainEngineThread is returning 1624 === Verbose logging stopped: 06/08/2011 23:50:32 ===
Andre,
Do you have other Autodesk applications on your machine?
I think the best solution for this type of issue is to perform a clean install of your Autodesk applications.
Use the following link to guide you through this process:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240697
After this, you should be able to install ACAD and InvFusion
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
You're welcome!
Darin Green
