Installation & Licensing
Trouble installing Autocad 2015
2 REPLIES 2
566 Views, 2 Replies
When I click the setup application I get the following error message:
Download and installation has been interrupted by a lost connection between the autodesk website and computer.  The most likely causes are:
Installation package was moved from the install location which is not supported.
The autodesk download website was closed or manually refreshed before the installer launched.  A firewall has blocked the network ports.
Please address these issues if possible, return to the website and then click again on Install now or use another download method. Download now or browerser download.
I tried turning off the firewall and it still didn't work.
Any help?
2 REPLIES 2
DarrenP
use the virtual assistant
You can access most current + previous supported version Browser Download links (including the Design & Creation Suites) through Matt, Autodesks Virtual Assistant. http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
>download links>Autocad Products>Autocad
Please accept as a solution if this fully resolves the issue
DarrenP
in reply to: DarrenP
Works perfect!!!!
thank you very much
Administrator Productivity
