Installation & Licensing
Trouble installing AutiCAD Architure 2014
3 REPLIES 3
368 Views, 3 Replies
I get an error when trying to install, any ideas what to do? 2014/3/4:21:37:50 MIN MIN-ABOOK === Setup started on MIN-ABOOK by MIN === 2014/3/4:21:37:50 MIN MIN-ABOOK Path_Length: 155 2014/3/4:21:37:50 MIN MIN-ABOOK Current Directory C:\Users\MIN\AppData\Local\Temp\_AIA4B8.tmp 2014/3/4:21:37:50 MIN MIN-ABOOK Launch 2014/3/4:21:37:50 MIN MIN-ABOOK Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\MIN\AppData\Local\Temp\_AIA4B8.tmp\Setup\AcSetup.dll 2014/3/4:21:37:50 MIN MIN-ABOOK Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2014/3/4:21:37:52 MIN MIN-ABOOK PageOpen LaunchDialog 2014/3/4:21:37:54 MIN MIN-ABOOK PageOpen LicenseDialog 2014/3/4:21:37:57 MIN MIN-ABOOK PageOpen ProductInfoDialog 2014/3/4:21:38:02 MIN MIN-ABOOK PageOpen ProductSelectionDialog2 2014/3/4:21:38:22 MIN MIN-ABOOK PageOpen FullProgressDialog 2014/3/4:21:38:22 MIN MIN-ABOOK Installing DirectX Runtime: "C:\Autodesk\AutoCAD_Architecture_2014_English_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent 2014/3/4:21:39:03 MIN MIN-ABOOK Install DirectX Runtime Succeeded 2014/3/4:21:39:03 MIN MIN-ABOOK Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\AutoCAD_Architecture_2014_English_Win_64bit_dlm\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® Architecture 2014" SETUP_PACKAGECODE={5783F2D7-D004-0000-0002-0060B0CE6BBA} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,.NET Framework Runtime 4.0 KB2468871,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Architecture_2014_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/3/4:21:39:08 MIN MIN-ABOOK Install Autodesk Content Service Succeeded 2014/3/4:21:39:08 MIN MIN-ABOOK Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® Architecture 2014" SETUP_PACKAGECODE={5783F2D7-D004-0000-0002-0060B0CE6BBA} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Architecture_2014_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/3/4:21:39:09 MIN MIN-ABOOK Install Autodesk Content Service Language Pack Succeeded 2014/3/4:21:39:09 MIN MIN-ABOOK Installing Autodesk® AutoCAD® Architecture 2014: TRANSFORMS="C:\Autodesk\AutoCAD_Architecture_2014_English_Win_64bit_dlm\x64\en-us\ACA\ACA.mst;C:\Users\MIN\AppData\Local\Temp\_AIA4B8.tmp\x64\ACA\ACA-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Architecture_2014_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/3/4:21:41:52 MIN MIN-ABOOK Install Autodesk® AutoCAD® Architecture 2014 Failed Installation aborted, Result=1603 2014/3/4:21:41:53 MIN MIN-ABOOK Rollback Autodesk Content Service Language Pack Succeeded 2014/3/4:21:41:55 MIN MIN-ABOOK Rollback Autodesk Content Service Succeeded 2014/3/4:21:41:55 MIN MIN-ABOOK Rollback DirectX Runtime Failed Failure is ignored, Result=1619
3 REPLIES 3
dembkod
ralflauritzen
Hello. Are you using an “Install Now” option? If so, I would use the “browser download” option to get the full program for install. I would make sure to have a complete download first. Also, you may want to run the MS fixit tool and try to uninstall the program first. If there are residual traces, this might help.
http://support.microsoft.com/mats/Program_Install_and_Uninstall\
Thank you for taking part in our community!
David Dembkoski
in reply to: dembkod
I have tried to install it by browser download, also by download manager.
Before i did anything i tride to run run it by ms fixit tool. Nothing seems
to be working at all, i keep getting this error code, dont know what it
means. Its the same error code no matter what i do.
Venlig hilsen
Ralf Lauritsen
pendean
While you wait... search around here for 1603 and 1619 errors (your two primary issues), there are many solutions posted.
Administrator Productivity
