Installation & Licensing
Tried Maya 2012 (657D1 2012.0.0.F), error 20 ,Please help
3 REPLIES 3
Ali_mohamed
5136 Views, 3 Replies
Dears,
I am having a strange problem in running Maya.
License was installed correctly
Deployment was created also but when we run Maya from the clients it refuses to obtain a license and the error is below:
License was not obtained
License method:
environment variable MAYA_LICENSE_METHOD='network'
Product choice:
environment variable MAYA_LICENSE='unlimited'
License file override:
environment variable MAYA_ALT_EN is not set
3 REPLIES 3
david.lau
in reply to: Ali_mohamed
Look for the C:\flexlm\maya.lic file.  Edit the file using Notepad and edit the license file as necessary.  Typically, it will look like:
SERVER servername 0
USE_SERVER
Alternate file can be:
SERVER ip-address-of-server 0
USE_SERVER
David Lau
I have the exact same problem and I get the exact same message. I have tried to uninstall and reinstalled, but failed. I have even tried to install Maya 2011, but I still get the same error.
Interesting note: I have the same product key as you for Maya 2012, 657D1. I think MAYBE Autodesk is sending out corrupt product trials for students and that's why these installs aren't working.
P.S. I tried to install AutoCad for Mac and I got the same error, it won't boot up. My product key is 777D1. Would you by any chance be having the same problem?
Johnny
Johnnythaitran@gmail.com
blinkwonatie2
I am running Maya 2012 Hotfix 4 on Mac OS X 10.6.8.
I am having a similar problem, but with a standalone licesnse for Maya Unlimited.
License method:
environment variable MAYA_LICENSE_METHOD='standalone'
Product choice:
Maya used to work fine, but this problem suddenly began happening. Any help would be greatly appreciated.
Administrator Productivity
