I'm going to upgrade from LT 2008 to 2014. I downloaded the trial to my laptop and the installation failed to complete but the program is running but without the Start menu links being installed.
I just tried to do the download onto my desktop PC. The installation failed after appearing to be near completion. This has happened twice.
I'm hesitant to spend the money for the new version if the download won't install.
Windows 8
Intel I5 3.4 system
8 gig of RAM
BH
Here is the log file of he install:
2014/2/13:07:34:11 BH Davis OFFICE === Setup started on OFFICE by BH Davis ===
2014/2/13:07:34:11 BH Davis OFFICE Path_Length: 152
2014/2/13:07:34:11 BH Davis OFFICE Current Directory C:\Autodesk\AutoCADLT_2014_SWL_English_Win_32_64bit_wi_en-us
2014/2/13:07:34:11 BH Davis OFFICE Launch
2014/2/13:07:34:11 BH Davis OFFICE CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/AutoCADLT_2014_SWL_English_Win_32_64bit_wi_en-us_... /akamai /auth authparam /sid SESSION_ID
2014/2/13:07:34:11 BH Davis OFFICE Current Directory C:\Users\BHDAVI~1\AppData\Local\Temp\_AI151F.tmp
2014/2/13:07:36:02 BH Davis OFFICE === Setup ended ===
2014/2/13:07:34:12 BH Davis OFFICE === Setup started on OFFICE by BH Davis ===
2014/2/13:07:34:12 BH Davis OFFICE Path_Length: 152
2014/2/13:07:34:12 BH Davis OFFICE Current Directory C:\Users\BHDAVI~1\AppData\Local\Temp\_AI151F.tmp
2014/2/13:07:34:12 BH Davis OFFICE Launch
2014/2/13:07:34:15 BH Davis OFFICE Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/{DD86A595-6C57-42A2-874F-C81BDF5A0EFA}/SETUP_x64....
2014/2/13:07:36:02 BH Davis OFFICE Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/{DD86A595-6C57-42A2-874F-C81BDF5A0EFA}/SETUP_x64....
2014/2/13:07:36:02 BH Davis OFFICE Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\BHDAVI~1\AppData\Local\Temp\_AI151F.tmp\Setup\AcSetup.dll
2014/2/13:07:36:02 BH Davis OFFICE Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/13:07:36:02 BH Davis OFFICE PageOpen LaunchDialog
2014/2/13:09:02:48 BH Davis OFFICE PageOpen LicenseDialog
2014/2/13:09:02:52 BH Davis OFFICE PageOpen ProductInfoDialog
2014/2/13:09:02:56 BH Davis OFFICE PageOpen ProductSelectionDialog2
2014/2/13:09:03:11 BH Davis OFFICE PageOpen FullProgressDialog
2014/2/13:09:03:12 BH Davis OFFICE Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/{DD86A595-6C57-42A2-874F-C81BDF5A0EFA}/DIRECTX.ta...
2014/2/13:09:03:37 BH Davis OFFICE Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/{DD86A595-6C57-42A2-874F-C81BDF5A0EFA}/DIRECTX.ta...
2014/2/13:09:03:37 BH Davis OFFICE Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD LT 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/2/13:09:03:45 BH Davis OFFICE Install DirectX Runtime Succeeded
2014/2/13:09:03:46 BH Davis OFFICE Download Play CM http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/{DD86A595-6C57-42A2-874F-C81BDF5A0EFA}/CM.tar.lzm...
2014/2/13:09:05:08 BH Davis OFFICE Download Complete CM http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/{DD86A595-6C57-42A2-874F-C81BDF5A0EFA}/CM.tar.lzm...
2014/2/13:09:05:08 BH Davis OFFICE Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® LT 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD LT 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/13:09:05:19 BH Davis OFFICE Install Autodesk Material Library 2014 Succeeded
2014/2/13:09:05:20 BH Davis OFFICE Download Play CMILB http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/{DD86A595-6C57-42A2-874F-C81BDF5A0EFA}/CMILB.tar....
2014/2/13:09:07:11 BH Davis OFFICE Download Complete CMILB http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/{DD86A595-6C57-42A2-874F-C81BDF5A0EFA}/CMILB.tar....
2014/2/13:09:07:11 BH Davis OFFICE Installing Autodesk Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® LT 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD LT 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/13:09:07:23 BH Davis OFFICE Install Autodesk Material Library 2014 - Base Image Library Succeeded
2014/2/13:09:07:23 BH Davis OFFICE Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD LT 2014\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® LT 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD LT 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/13:09:07:27 BH Davis OFFICE Install Autodesk Content Service Succeeded
2014/2/13:09:07:27 BH Davis OFFICE Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® LT 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD LT 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/13:09:07:29 BH Davis OFFICE Install Autodesk Content Service Language Pack Succeeded
2014/2/13:09:07:29 BH Davis OFFICE Download Play ACADLT http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/{DD86A595-6C57-42A2-874F-C81BDF5A0EFA}/ACADLT_x64...
2014/2/13:09:15:05 BH Davis OFFICE Download Aborted ACADLT http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/{DD86A595-6C57-42A2-874F-C81BDF5A0EFA}/ACADLT_x64...
2014/2/13:09:15:05 BH Davis OFFICE Install Autodesk® AutoCAD LT® 2014 Failed Download Failed, Installation aborted, Result=1603
2014/2/13:09:15:07 BH Davis OFFICE Rollback Autodesk Content Service Language Pack Succeeded
2014/2/13:09:15:43 BH Davis OFFICE Rollback Autodesk Content Service Succeeded
2014/2/13:09:15:55 BH Davis OFFICE Rollback Autodesk Material Library 2014 - Base Image Library Succeeded
2014/2/13:09:16:21 BH Davis OFFICE Rollback Autodesk Material Library 2014 Succeeded
2014/2/13:09:16:21 BH Davis OFFICE Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/2/13:09:16:21 BH Davis OFFICE PageOpen InstallCompleteDialog
2014/2/13:09:20:16 BH Davis OFFICE === Setup ended ===
2014/2/13:09:21:48 BH Davis OFFICE === Setup started on OFFICE by BH Davis ===
2014/2/13:09:21:48 BH Davis OFFICE Path_Length: 152
2014/2/13:09:21:48 BH Davis OFFICE Current Directory C:\Autodesk\AutoCADLT_2014_SWL_English_Win_32_64bit_wi_en-us
2014/2/13:09:21:48 BH Davis OFFICE Launch
2014/2/13:09:21:48 BH Davis OFFICE CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/AutoCADLT_2014_SWL_English_Win_32_64bit_wi_en-us_... /akamai /auth authparam /sid SESSION_ID
2014/2/13:09:21:48 BH Davis OFFICE Current Directory C:\Users\BHDAVI~1\AppData\Local\Temp\_AI99C3.tmp
2014/2/13:09:21:49 BH Davis OFFICE === Setup ended ===
2014/2/13:09:21:49 BH Davis OFFICE Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/{DD86A595-6C57-42A2-874F-C81BDF5A0EFA}/SETUP_x64....
2014/2/13:09:21:49 BH Davis OFFICE Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\BHDAVI~1\AppData\Local\Temp\_AI99C3.tmp\Setup\AcSetup.dll
2014/2/13:09:21:49 BH Davis OFFICE Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/13:09:21:49 BH Davis OFFICE PageOpen LaunchDialog
2014/2/13:09:21:52 BH Davis OFFICE PageOpen LicenseDialog
2014/2/13:09:21:55 BH Davis OFFICE PageOpen ProductInfoDialog
2014/2/13:09:21:59 BH Davis OFFICE PageOpen ProductSelectionDialog2
2014/2/13:09:27:18 BH Davis OFFICE PageOpen FullProgressDialog
2014/2/13:09:27:19 BH Davis OFFICE Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/{DD86A595-6C57-42A2-874F-C81BDF5A0EFA}/DIRECTX.ta...
2014/2/13:09:27:19 BH Davis OFFICE Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD LT 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/2/13:09:27:21 BH Davis OFFICE Install DirectX Runtime Succeeded
2014/2/13:09:27:21 BH Davis OFFICE Download Skipped CM http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/{DD86A595-6C57-42A2-874F-C81BDF5A0EFA}/CM.tar.lzm...
2014/2/13:09:27:21 BH Davis OFFICE Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® LT 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD LT 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/13:09:27:33 BH Davis OFFICE Install Autodesk Material Library 2014 Succeeded
2014/2/13:09:27:33 BH Davis OFFICE Download Skipped CMILB http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/{DD86A595-6C57-42A2-874F-C81BDF5A0EFA}/CMILB.tar....
2014/2/13:09:27:33 BH Davis OFFICE Installing Autodesk Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® LT 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD LT 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/13:09:27:44 BH Davis OFFICE Install Autodesk Material Library 2014 - Base Image Library Succeeded
2014/2/13:09:27:44 BH Davis OFFICE Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD LT 2014\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® LT 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD LT 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/13:09:27:48 BH Davis OFFICE Install Autodesk Content Service Succeeded
2014/2/13:09:27:48 BH Davis OFFICE Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® LT 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD LT 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/13:09:27:50 BH Davis OFFICE Install Autodesk Content Service Language Pack Succeeded
2014/2/13:09:27:51 BH Davis OFFICE Download Play ACADLT http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/{DD86A595-6C57-42A2-874F-C81BDF5A0EFA}/ACADLT_x64...
2014/2/13:09:35:27 BH Davis OFFICE Download Aborted ACADLT http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/{DD86A595-6C57-42A2-874F-C81BDF5A0EFA}/ACADLT_x64...
2014/2/13:09:35:27 BH Davis OFFICE Install Autodesk® AutoCAD LT® 2014 Failed Download Failed, Installation aborted, Result=1603
2014/2/13:09:35:28 BH Davis OFFICE Rollback Autodesk Content Service Language Pack Succeeded
2014/2/13:09:35:31 BH Davis OFFICE Rollback Autodesk Content Service Succeeded
2014/2/13:09:35:43 BH Davis OFFICE Rollback Autodesk Material Library 2014 - Base Image Library Succeeded
2014/2/13:09:36:10 BH Davis OFFICE Rollback Autodesk Material Library 2014 Succeeded
2014/2/13:09:36:10 BH Davis OFFICE Rollback DirectX Runtime Failed Failure is ignored, Result=1619
Hello. Uninstall whatever is installed on your machine using the MS Uninstall tool:
http://support.microsoft.com/mats/Program_Install_and_Uninstall\
After this, I would get eth trial again, but not use “Install Now”. Click the arrow next to the button and set to “Download Now”. Then download the program completely and then run the setup.exe installer from the download folder.
http://www.autodesk.com/products/autodesk-autocad-lt/free-trial
Thank you for taking part in our community!
Thanks for the quick reply.
Will the MS uninstall have any impact on my AutoCAD LT 2008 installation? From what you are saying it sounds like it will only remove the LT 2014 files.
BH
