Installation & Licensing
Transferring Menus to ACAD 2010
4 REPLIES 4
caltomare
296 Views, 4 Replies
I have a subscription and upgraded from ACAD2008 to 2009 to 2010.
For ACAD2010, it appears that ACAD made a new CUIX file that is my customization file.
However my menu command does not work.
In ACAD 2008 I load DDS.lsp   Menuset.lsp and RHSite.lsp.
In ACAD2010  these are unknown commands. How can I correct this because I need my menus and DDS to  set up my drawing template.
Chris
4 REPLIES 4
pendean
in reply to: caltomare
CUI and CUIx screen menu files do not load LISP files: explore using APPLOAD>Startup option or creating/editing your ACADDOC.LSP file to load those lisp files for you, just like you did in the earlier version. Migration does not pick up APPLOAD functions, it just moves menu files and other shared file from one version to another.
Do you know how your previous AutoCAD was set up to load those lisp files?
caltomare
This is the script that is loaded when I launch ACAD 2008
Unfortunately I am a user not the person who created the .LSP files
For ACAD 2008, we had to select a profile which is an .ARG file.
Does this help?
Customization file loaded successfully. Customization Group: RHPID
Customization file loaded successfully. Customization Group: CUSTOM
Customization file loaded successfully. Customization Group: EXPRESS
Customization file loaded successfully. Customization Group: USER171
Regenerating model.
AutoCAD Express Tools Copyright © 2002-2004 Autodesk, Inc.
AutoCAD menu utilities loaded.
Loading RH standard modules.
  DDS.LSP....... loaded.
  MENUSET.LSP ...loaded.
  RHSITE.LSP ....loaded.
Start Up for Engineering Division Bristol.
PlantCAD NOT available for this version of AutoCAD.
Visual Tablet NOT installed.
Command: COMMANDLINE
pendean
Does your R2008 seat have an ACAD.LSP or ACADDOC.LSP file? Move them over to R2010, in one of the Search path folders.
And are the lisp files you want to lead in R2010's Search paths (OPTIONS command>Files Tab>Search Path... entry at the top)?
caltomare
in reply to: pendean
The answer to both questions is Yes.
The file ACAD.lsp is already in the folder at the top of the list.
Administrator Productivity
