Installation & Licensing
transfare the License from old laptop to new one.
1 REPLY 1
472 Views, 1 Reply
Dear Sir,
I changed my laptop because I had fetal problem in the old machine (its not working now), i want to transfare the License  to the new laptop.
please let me know how can i transfare the License.
Regards.
Osama Jalal
1 REPLY 1
TravisNave
Welcome to the peer forums!
This is a common issue.  Reactivation is the best method here.  If your license is still valid, then you can simply reactivate it automatically on the Internet.  If you have problems, then you can activate it manually with an activation code from Autodesk.
You can use the online method to activate your license here:
http://usa.autodesk.com/adsk/servlet/pc/item?id=18424632&siteID=123112
If the license is no longer valid, then it will not activate, nor will the license transfer utility move it.
Good Luck!
Autodesk Forums:
Administrator Productivity
