Can network deployment packages be created on a local machine, copied to a network storage location, and installed from by local
network users?
If yes, are there any files that contain a UNC path / filename reference that will need to be changed to the UNC path of the final network storage location?
It would be much easier to create network deployments locally, and let them copy to the network overnight, unattended.
Also, I have a problem with installations from deployment failing on the Microsoft C++ Redistributable Package. Look for this in a separate post.
Dave
