When a user closes Inventor how long until their license returns to the pool for a different user to pick it up?
What is the minimum & how can it be enforced?
Rgds
MES
Solved by DarrenP. Go to Solution.
when you close it returns the license in the pool unless you borrowed a license from the pool then varies
you can set up whats called an options file to control that: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7459915&linkID=9240617
DarrenP
Is the license returned to the pool instantly or does it take 15 minutes?
MES
it should be instant
DarrenP
