Hi there! I recently installed Autodesk 3DS Max 2013 and for some apparent weird reason, whenever I start the program, I recieve this message:
The software license failed to initialize
Error 10
I have no idea what or how that error can come about, I have my Product key and my serial number with me. Do I have to input it somewhere in order for it to work?
Also, I've heard methods about re-installing, I haven't tried that yet but if that doesn't work, is there a plan B?
Also, there is no FlexNet files or service on my computer from what I've seen. I'm running on Windows 7 64bit by the way. My DirectX is also fully updated.
Thanks! -Aj
Solved by TravisNave. Go to Solution.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17905584&linkID=9240617
Error 10 is almost always invalid serial number or activation limit reached. But it might be more involved than that.
I see your point, but the thing is that I downloaded and installed it yesterday and theres nobody else in my entire house or family that uses this program. I'll consider a simple reinstall to see how it goes.
