Installation & Licensing
The software license checkout failed error 20
4 REPLIES 4
5304 Views, 4 Replies
I get the message “The software license checkout failed error 20” when you start 3dsMax.
I have Windows7 64bits,
I deleted:
C:\Users\<username>\AppData\Roaming\Autodesk\ADUT
C:\ProgramData\Autodesk\ADUT
C:\ProgramData\FLEXnet
I reset FlexNet Licensing Service 64
but nothing works
4 REPLIES 4
Otto
Hello Reinva and welcome to the Autodesk community!
It looks like you are seeing License was not obtained: error 20. The following articles should help you resolve the problem:
How to force re-activation of a product
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Darin.Green
If you deleted those directories, while the software is still installed, that's not going to help but instead make things worse.
That being said, you'll need to uninstall the software and once that's completed, you need to make sure you also delete the following:
  • C:\ProgramData\Autodesk
  • C:\Program Files\Autodesk
  • C:\Program Files\Common Files\Autodesk Shared
If you need assistance with this, use the Clean Uninstall link in my signature under Resources.
If this information was helpful, please consider using the Accept Solution
in reply to: Darin.Green
when I delete these folders already had uninstalled the program. Also delete any registry key that had the word autodesk, delete any folder that had the word autodesk, delete the temporary folder, but when I returned to install 3dsmax the error remained.
Can I retesting without wait an hour to download the program for the third time? Is the previous download is somewhere? They can give me a link to download the program once and to make all necessary facilities?
I uninstall, clean and install four times for now and I get the same result.
Any solution for me?
Administrator Productivity
