I have Windows XP Professional, and I accidentally uninstalled 3ds Max 2011 (32-bit). I used System Restore to get it back on my laptop, and used the repair option of 3ds Max on the Add or Remove Programs section to try and fix it up. But now whenever I tried opening 3ds max, but it keeps saying 'The software license check out failed. Error 25.'
Can someone help me out?
Can you remove the .data file and then re-launch product? The .data file is located here:
I solved it. I deleted the the ProductInformation.pit file that caused the problem and I uninstalled 3ds max to re-installed it, and it worked.
Thanks for the tip. :3
Actually I did get a response from support to this article:
which was equally unhelpful since none of the reference files are in my system.
Hello. I have Windows 7 Home Premium and I cannot open Autodesk 3ds Max 2013 x64. I have deleted the file that is in this post but it is not working. I have even uninstalled the program twice and installed back again.
I will upload a picture with the problem.
Any help would be useful.
Thanks.
Sebastian
Bonjour,
J'ai installé REVIT 2016 sans succès (message d'erreur "erreur du système de licence 25".
On a enlevé les deux fichiers C:/ProgramData/Flexnet/adstflex_00691600_tsf.data
C:/ProgramData/Flexnet/adstflex_00691600_tsf.data_backup.001
En relançant REVIT cela ne marche toujours pas.
HELP !!!
Hello @Artinstruction7,
Welcome. Are you experiencing the same exact issue? What error are you receiving & for what product & version?
To see all program folders make sure they are not hidden.
Keep us posted.
Please "Accept As Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Please help me, what have you done? Where did you get this file? to delete
