Installation & Licensing
The setup wizard isn't letting me install; it says inventor is already installed
2 REPLIES 2
colinc12
734 Views, 2 Replies
During my initial setup, I was installing to an external hard drive and halfway through the inventor installation, it crashed and died.... My computer registered as installing inventor, so when I went back into the wizard, it still said that inventor was already installed. I was able to download everything else, but I need inventor desperately. How can I get the wizard to acknowledge that I do not have inventor installed?
2 REPLIES 2
TravisNave
in reply to: colinc12
Installing to a removable device probably isn't a good idea.  But in any case, try one of these solutions:
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
For all other installation problems consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
Autodesk Forums:
in reply to: TravisNave
Worked for the same Problem for Autodesk Vault Professional 2018 .
Thanks!
Administrator Productivity
