I am trying to activate my autodesk student liscense for 3ds max but I am getting this error when I choose the "connect now and activate" option: The serial number you entered is not valid. Try again. (Error 2).
Please help, this problem is really bugging me.
Solved by camilo.lemos. Go to Solution.
I am also getting the same problem, which is the serial number not being valid. I am trying to activate 3DS Max with a student license. Can you please help
Hi @jrodriguez1426,
I was able to pull up your EDU Account using the email address on file.
I am not seeing any 3ds Max, the Products under your account are Autodesk AutoCAD 2014, Autodesk Maya 2014 and Autodesk Inventor Professional 2015.
Please try to download the Product from the site. Let us know if you're still having issues.
I am having the same issue installing Autocad Civil 3d from the educator website. How do I get this resolved?
Hello, I am having the same issue, I would appreciate it if someone could help. My code worked when I first got the installer working, but now it won't.
Thanks.
Hi @jess.jarvis Welcome to Autodesk Community!
Sorry that you're having trouble with the student license. The current workaround is to create a new Education Community account using a different e-mail address and AutodeskID. Then try the download and installation again. Let us know if it works!
Hi @Anonymous Welcome to Autodesk Community!
Sorry that you're having trouble with the student license. You might need a new serial number. Please create a new Education Community account using a different e-mail address and AutodeskID. Then try the download and installation again. Let us know if it works!
I am having this same problem, can you help.
Hi @Hubbard1866 and welcome to the Autodesk Community!
As indicated by Lynn, the easiest way around this issue is to register a new Education Community account with a different email address and obtain a new serial number.
There is no need to fully download the program again, simply go as far as obtaining the serial number.
I hope this helps!
