I am trying to activate my autodesk student liscense for 3ds max but I am getting this error when I choose the "connect now and activate" option: The serial number you entered is not valid. Try again. (Error 2).
Please help, this problem is really bugging me.
Solved by camilo.lemos. Go to Solution.
Hey, i installed 3ds max 2013 (student) and I'm getting "The serial number you entered is not valid. Try again (1). I get this message after clicking "connect now and activate"
Could I get help for this?
Hi jeremycreid,
I checked your EDU Account and I am not seeing any downloaded software yet nor any Serial Number. Please do try downloading the software again using the log in details I sent via Private Message (click on the small envelope beside your profile name at the upper right side of the page).
Hi bon_bovi,
Please send me a Private Message (click on my camilo.lemos profile name and then "Send this user a private message") with your serial number and product request code.
Thank you.
Hi,every time I start Autocad Mechanical 2013, I get an error at the license screen and I have to restart the PC. I'm attaching a pricture with the error.
Thanks in advance.
I'm also having the same issue trying to activate the Revit Architecture 2012.
Upon my initial attempt to download the software I received the following screen::
"Error assigning serial number to product: This is an operation implementation generated fault"
However I still had the BROWSER DOWNLOAD button available on the same screen and downloaded and installed, entering the serial number and product key which were also both provided on the screen.
However once I tried to activate with the same codes I then got the Serial Number is Invalid Problem.
Any help would be greatly appreciated.
Hi andrew_anthony,
Please send me a Private Message (click on my joane.bonghanoy profile name and then “Send this user a private message”) with your Serial Number and Request Code.
Another one here... I PM'd the info to Joane but just in case she's away, is there someone else I should be sending this information to?
Hi Sean,
Since Joane is not available at the moment please direct the PM to me. (Click on my amanda.k profile name and then “Send this user a private message”) with your Serial Number and Request Code.
Hi g_iles,
Looking at your account, the quickest option for you would be to just register a new account with a different e-mail address and get a new serial number (you don't need to fully re-download the software; simply get to the part where the website gives you a serial number and use that new number to register your already installed program).
Best regards,
Hi Joanne, can you help me too? I have this same problem where the serial number i entered isnt valid. my serial number is xxx xxxx xxxxand the programme is Autodesk 3DMAx Design 2013. Thanks a lo Joanne
Edited by
Discussion_Admin
I purchased Autocad 2009 at work late 2008 but then moved to another position and never installed or activated, i am back into mild autocad activity and tried to install, have S/N and activation code from the time of purchase but receive system error S/N is not valid. Try again. Can not activate the product
Hello Eduardo!
"The serial number you entered is not valid" error is typically caused by a license that was upgraded per a subscription contract which has since expired. As it turns out that is exactly the case with your AutoCAD 2009 license which was upgraded to AutoCAD 2011.
With that being said, I'll send you a Private Message momentarily with the upgraded licensing information and corresponding download links.
Please accept as a solution if this fully answers your inquiry, or reply with additional questions as needed.
I am having the same problem with my serial number on 3ds Max 2010 64-bit.
What can I do to fix the problem?
thank you,
Hi Joe!
Your best bet for activation support or will always be directly contacting our License Assistance Team.
With that being said, it also looks like your license was upgraded (in your case to 3ds Max 2011) and as the newer version has not yet been activated, you're entitled to use the 2010 software.
I'll send you a Private Message momentarily with the upgrade info. Should you wish to stay on 2010, please reply with the serial number and request code so that I can generate an activation code.
Hi SanieML,
Please send me a Privated Message (click on my joane.bonghanoy profile name and then “Send this user a private message with your Serial Number so I can check on it.
Product Registration & Activation...
The serial number you entered is not valid Try again (1).
Do AutoCad LT 2010 Have any expiration date? Our company register LT 2010 for two years ago and now its not workning?
Hi ellman,
Our commercial licenses are not normally set up to expire. However, I see that you are a subscription customer so what probably happened is that your 2010 software was upgraded to the most current version, which would prevent you from activating an older version-
I can check this for you if you send me the serial number in question via Private Message (click on my camilo.lemos profile name and then on Send This User a Private Message).
Best regards,
