I have problems to activate my ACAD 2012, Can you help me?
Thanks!
Hdo
"The serial number you entered is not valid" error typically indicates that activation count on the entered serial number has reached the limit.
I would suggest contacting The Autodesk Registration and Authorization office (Mon-Fri) phone: 1-800-551-1490.
I was calling to Autodesk office and I don´t had answer.
Is posibble to solve this problem online?
regards
I can help you out with this one Hernando.
Please send me a Private Message (click on my philip.s profile name and then "Send this user a private message") with all of your relevant licensing information including your serial number and product request code.
I bought the software off the internet with a Company called Ingrated Software Solution. The Software they sold me was AutoCad Architecture 2012. It is in a case and it came with two CD's, one is the 32 bit and the other is 64 bit. I needed to install the 32 bit. The Serial Number looks real. The Number is XXX-XXXXXXXX with a product key of 185D1. Why won't it activate. Don't tell me I got burned by this company. Can you help?
Hello Terry and welcome to the community.
As this is a public forum, please refrain from posting sensitive information such as serial numbers (I've edited / removed it from your initial response).
The serial number that you provided (ending in 3254) is not in our system With that being said, we're only able to support licenses purchased through an Autodesk Authorized Reseller and I'd strongly suggest contacting this particular seller and requesting a refund.
Please let me know if you have any additional questions!
