i just installed AIP2011 suite (entire bundle inc vault, acadm etc) and after successfull activation of inventor i am being asked to activate acadm 2011 when i try to start it. if i use my new serial number i recieve this result : quote "...The serial number you entered is not valid. Try again. (1)".
autodesk support are saying that it does not need separate activation since it is part of the bundle. this is true of every other install i have carried out however this time i am stuck in a perpetual loop that being, support says no activation of acadm 2011 is needed, and the software is requesting an activation code upon startup.
the 30 day counter is ticking down.
i have requested new activation codes, to no avail.
see following quoted response from support:
quote "... Thank you for your request.
(1)The serial number xxx-xxxxxxxx belongs to the product [AutoCAD
Inventor Professional Suite 2011] and not to the [AutoCAD Mechanical
2011]. Thus we are unable to activate [AutoCAD Mechanical 2011] using
this serial number.
(2)We would like to apologize for the inconvenience caused. The
Registration and Activation department specializes in the registration
and activation of your software. Autodesk Authorized Resellers or
Autodesk contract contact person are the primary source of technical
support for Autodesk products.
If you purchased your software online you will be able to get technical
support via our website http://discussion.autodesk.com... " end quote.
earlier response - quote "...
We would like to apologize for the inconvenience caused. Since AutoCAD
Inventor Professional Suite 2011 has already been activated, you can now
use AutoCAD Mechanical 2011 without having it activated since this
product is already bundled under AutoCAD Inventor Professional Suite
2011.
For further technical assistance please contact your authorized Autodesk
reseller.
Thank you for contacting Autodesk.
Kind regards,
..." end quote.
best regards,
- Mark
(Kudo or Tag if helpful - in case it also helps others)
PDSU 2020 Windows 10, 64bit.
