Installation & Licensing
New Member
adilet.askarbek
Message 1 of 2 (91 Views)
The program Autodesk Maya2014 Student Version. It is not closed
91 Views, 1 Replies
08-15-2013 07:35 AM
майя.jpgHello! I had a problem with the program Autodesk Maya2014 Student Version. It is not closed. Please help.
TravisNave
Message 2 of 2 (84 Views)
Re: The program Autodesk Maya2014 Student Version. It is not closed
08-15-2013 08:09 AM in reply to: adilet.askarbek
Welcome to the community.
This problem could be caused by a couple of things.
1.  You are running out of heap space in Windows.  You can correct this by using the Fix it option in this Microsoft KB article:
http://support.microsoft.com/kb/947246
2.  You are running into a video driver anamoly.  What you might try doing is upgrading your video card driver to a WHQL certified driver as a clean install and reboot.  Programs like Maya are graphic intensive, so you need to have a stable video driver.  Never run a Microsoft compatible or factory installed driver.
Good Luck!
