Hello! I had a problem with the program Autodesk Maya2014 Student Version. It is not closed. Please help.
Welcome to the community.
This problem could be caused by a couple of things.
1. You are running out of heap space in Windows. You can correct this by using the Fix it option in this Microsoft KB article:
http://support.microsoft.com/kb/947246
2. You are running into a video driver anamoly. What you might try doing is upgrading your video card driver to a WHQL certified driver as a clean install and reboot. Programs like Maya are graphic intensive, so you need to have a stable video driver. Never run a Microsoft compatible or factory installed driver.
Good Luck!
