Show only
Search instead for
It's quite simple. First you need to create a file with Notepad and name it with the exact filename of adskflex.opt. Inside this file is where you place the different options that you wish to enable with your Network License Manager. For example, if you use TIMEOUTALL 900, then your licenses will return after 15 minutes of inactivity. You must save this file in the same location as your license .LIC file. Once done, simply do a reread of your license from within LMTOOLS and you will be all set.
If you have any more questions about this, feel free to post here. Good Luck!
Travis Nave Need help in your post? Mention me with @TravisNave
