first of all, I searched in these forums and also on the other places in the internet.
Ther're a lot of hints, tipps etc. but most of them are not working in our case, or are impossible to use.
Our Situation:
We are trying to install the Product Design Suite Standard / Professional 2014 via network deployment.
So, I created a network deployment as usual on my local PC and then copied it to the server and changed all necessary files. Then I deleted all local files and tried the installation on my PC. Everything fine.
Now a different person used my deployment and it is not working, he gets this message:
"The copy functions cannot be used" and after clicking on ok, he gets the next message for a different file.
This user has 100% the same permissions I have (it's a cloned user).
The network is connected and the line is also stable. Regarding the hints in the internet, we've tried the following steps:
1. Check the permissions on local and network drives
2. Checked the UAC Settings
3. Created a second deployment directly on the server and not moving it from local to network, to make sure that I don't forget a thing 🙂
4. Deactivated the Antivir program
What we cannot do is the following:
Copy the files to the local drive and change all the ini files etc. to the local PC.
Why?
Because we have to do this job for more then 150 PC's around the globe (Global License Agreement) and that will not work. Then we can go directly from PC to PC and can install the data from disc manually and we don't need a deployment.
So, is there a masterhint to this problem?
Best Regards to all
Passi
