Hello Team,
I just installed the 3ds Max Design 2013 and it completed successfully. However, when I try to launch it, I get an error box saying 'the application was unable to start correctly(0xc000007b). click ok to close the application.' Can you please help? My system details are as below.
OS: Windows 7 Professional 64bit
.NET: 4.5.50709
Visual C++: 10.0.40219
Installer filename: Autodesk_3ds_Max_Design_2013_EFGKJS_Win_64bit.exe
Thank you,
Bicky
These errors are very hard to troubleshoot.
Do you have a certified video card?
http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112
If you have a Geforce card, can you change graphics mode?
I would also post the question here:
http://forums.autodesk.com/t5/Autodesk-3ds-Max-3ds-Max-Design/bd-p/area-b200
Thanks for your reply. I do not have a separate graphics card on my laptop. I run a i5 with 4GB RAM..is this error due to these specifications?
Also can you confirm that the file I have used to install is correct for Windows 7 Professional? Lastly, is there any logs that the executable maintains that I can see for the error?
Please let me know.
Bicky
