Installation & Licensing
System Requirements not met (false)
5 REPLIES 5
tomiquaglia
607 Views, 5 Replies
When trying to install Autocad 2014, the program says that I don't meet the recommended system requirements, even though I do. My graphics card is on the list of certified hardware, and I meet all others system requirements. I was able to install 3DS MAX without any problem (more system requirements). I need help!
5 REPLIES 5
Do you also have the certified driver version of your graphiscs card installed?
tomiquaglia
in reply to: tomiquaglia
Yes, I installed it.
pendean
What are you system details?OS?32bit or 64bit? Which exact 2014 file did you download?
dembkod
tomiquaglia
Hello. Usually the message that appears is in relation to your Operating system. What is the OS? IF this is Vista, this is your problem. Also, I am wondering if you are running an install from our website or if you have tried an alternate method? I would download the whole installer to yoru machine and then install. It may help.
Thank you for taking part in our community!
David Dembkoski
tomiquaglia
I have Windows 7 Enterprise, 64-bit.
Intel Core 2 Duo E7500 2.93 ghz
NVIDIA 9600 GT
I tried installing Autocad 2014 64-bit, I download it from this website.
When I run the Setup, some messages pop up: Error 1606 could not acess to network location Autodesk/Autocad 2014, and #272 error AdskExecuteSquence, and I press Cancel and go on with the instalation. (until the system requirements message block it. )
Administrator Productivity
