Installation & Licensing
System Requirements 2
3 REPLIES 3
louisecmarins
289 Views, 3 Replies
I already had the 2014 AutoCAD version on my computer, but it was in portuguese... So i decided to install it in english and now I just can't finish the installation process. It says that have some problem with the System Requirements. To install it in english, i needed to uninstall the portuguese version and install again, because i wasnt getting right on the other way. What do I do?
3 REPLIES 3
Hi louisecmarins,
Please check that you met the System Requirements. If so, you can proceed with the uninstallation of the Portuguese version. Click here for the complete uninstallation steps.
Joane Bonghanoy
m_latz
in reply to: louisecmarins
Hhm, why uninstall the portuguese version. I recommend to install the english language pack, so you can use both.
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=21282814&linkID=9240618
regards
Markus
inchul.lee
Hi louisecmarins,
Both Joane's and m.latz's posts are good information to your issue. I've marked them as solutions.
Inchul Lee
Administrator Productivity
