Here it is
2014/6/19:13:47:11 Lise LISE_CLAUDE === Setup started on LISE_CLAUDE by
Lise ===
2014/6/19:13:47:11 Lise LISE_CLAUDE Path_Length: 143
2014/6/19:13:47:11 Lise LISE_CLAUDE Current Directory
C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/6/19:13:47:11 Lise LISE_CLAUDE Launch
2014/6/19:13:47:11 Lise LISE_CLAUDE CommandLine /url "
http://trial.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe"/akamai /skipEULA /auth authparam /sid SESSION_ID
C:\Users\LISE~1.LIS\AppData\Local\Temp\_AICAEB.tmp
2014/6/19:13:47:39 Lise LISE_CLAUDE === Setup ended ===
2014/6/19:13:47:15 Lise LISE_CLAUDE === Setup started on LISE_CLAUDE by
Lise ===
2014/6/19:13:47:15 Lise LISE_CLAUDE Path_Length: 143
2014/6/19:13:47:15 Lise LISE_CLAUDE Current Directory
2014/6/19:13:47:15 Lise LISE_CLAUDE Launch
2014/6/19:13:47:19 Lise LISE_CLAUDE Download Play SETUP_CONFIG
http://trial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.ta...2014/6/19:13:47:35 Lise LISE_CLAUDE Download Complete SETUP_CONFIG
http://trial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.ta...2014/6/19:13:47:37 Lise LISE_CLAUDE PageOpen LaunchDialog
2014/6/19:13:47:44 Lise LISE_CLAUDE PageOpen LicenseDialog
2014/6/19:13:47:44 Lise LISE_CLAUDE PageOpen ProductInfoDialog
2014/6/19:13:50:03 Lise LISE_CLAUDE PageOpen ProductSelectionDialog2
2014/6/19:13:50:27 Lise LISE_CLAUDE PageOpen FullProgressDialog
2014/6/19:13:50:28 Lise LISE_CLAUDE Download Play VCREDIST2012X86
http://trial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST2012...2014/6/19:13:50:34 Lise LISE_CLAUDE Download Complete VCREDIST2012X86
http://trial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST2012...2014/6/19:13:50:34 Lise LISE_CLAUDE Installing Microsoft Visual C++ 2012
Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya
2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/6/19:14:02:44 Lise LISE_CLAUDE Install Microsoft Visual C++ 2012
Redistributable (x86) Succeeded
2014/6/19:14:02:44 Lise LISE_CLAUDE WebInstaller2014/6/19:14:03:15 Lise
LISE_CLAUDE Download Play VCREDIST2012X64
http://trial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST2012...2014/6/19:14:03:22 Lise LISE_CLAUDE Download Complete VCREDIST2012X64
http://trial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST2012...2014/6/19:14:03:22 Lise LISE_CLAUDE Installing Microsoft Visual C++ 2012
Redistributable (x64): "C:\Autodesk\WI\Autodesk Maya
2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/6/19:14:15:36 Lise LISE_CLAUDE Install Microsoft Visual C++ 2012
Redistributable (x64) Succeeded
2014/6/19:14:15:36 Lise LISE_CLAUDE WebInstaller2014/6/19:14:15:47 Lise
LISE_CLAUDE Download Play DIRECTX
http://trial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar....2014/6/19:14:15:54 Lise LISE_CLAUDE Download Complete DIRECTX
http://trial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar....2014/6/19:14:15:54 Lise LISE_CLAUDE Installing DirectX® Runtime:
"C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/6/19:14:16:07 Lise LISE_CLAUDE Install DirectX® Runtime Succeeded
2014/6/19:14:16:08 Lise LISE_CLAUDE Download Play ADAPPLICATIONMANAGER
http://trial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/ADAPPLICATIO...2014/6/19:14:16:35 Lise LISE_CLAUDE Download Complete ADAPPLICATIONMANAGER
http://trial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/ADAPPLICATIO...2014/6/19:14:16:35 Lise LISE_CLAUDE Installing Autodesk Application
Manager: "C:\Autodesk\WI\Autodesk Maya
2015\x86\ADAPPLICATIONMANAGER\AdApplicationManager-WebInstaller.exe"
2014/6/19:14:30:03 Lise LISE_CLAUDE Install Autodesk Application Manager
Succeeded
2014/6/19:14:30:03 Lise LISE_CLAUDE WebInstaller2014/6/19:14:30:44 Lise
LISE_CLAUDE Download Play MAYA
http://trial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/MAYA_en-US.t...2014/6/19:14:47:09 Lise LISE_CLAUDE Download Aborted MAYA
http://trial.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/MAYA_en-US.t...2014/6/19:14:47:09 Lise LISE_CLAUDE Install Autodesk® Maya® 2015
Failed Download
Failed, Installation aborted, Result=1603
2014/6/19:14:47:15 Lise LISE_CLAUDE Rollback Autodesk Application Manager
Failed Failure is ignored, Result=1619
2014/6/19:14:47:16 Lise LISE_CLAUDE Rollback DirectX® Runtime Failed Failure
2014/6/19:14:47:17 Lise LISE_CLAUDE Rollback Microsoft Visual C++ 2012
Redistributable (x64) Failed Installation aborted, Result=1619
2014/6/19:14:47:18 Lise LISE_CLAUDE Rollback Microsoft Visual C++ 2012
Redistributable (x86) Failed Installation aborted, Result=1619
2014/6/19:14:47:21 Lise LISE_CLAUDE PageOpen InstallCompleteDialog
2014/6/19:14:47:53 Lise LISE_CLAUDE === Setup ended ===
2014/6/19:15:00:34 Lise LISE_CLAUDE === Setup started on LISE_CLAUDE by
Lise ===
2014/6/19:15:00:34 Lise LISE_CLAUDE Path_Length: 143
2014/6/19:15:00:34 Lise LISE_CLAUDE Current Directory
C:\Users\LISE~1.LIS\AppData\Local\Temp\_AI1384.tmp
2014/6/19:15:00:34 Lise LISE_CLAUDE Launch
2014/6/19:15:00:41 Lise LISE_CLAUDE [Error: 1056] Une instance du service
s’exécute déjà.
2014/6/19:15:00:41 Lise LISE_CLAUDE === Setup ended ===
2014/6/19:15:00:29 Lise LISE_CLAUDE === Setup started on LISE_CLAUDE by
Lise ===
2014/6/19:15:00:29 Lise LISE_CLAUDE Path_Length: 143
2014/6/19:15:00:29 Lise LISE_CLAUDE Current Directory
2014/6/19:15:00:29 Lise LISE_CLAUDE Launch
2014/6/19:15:00:29 Lise LISE_CLAUDE CommandLine
2014/6/19:15:01:05 Lise LISE_CLAUDE === Setup ended ===
2014/9/15:09:47:45 Lise LISE_CLAUDE === Setup started on LISE_CLAUDE by
Lise ===
2014/9/15:09:47:45 Lise LISE_CLAUDE Path_Length: 143
2014/9/15:09:47:45 Lise LISE_CLAUDE Current Directory
2014/9/15:09:47:45 Lise LISE_CLAUDE Launch
2014/9/15:09:47:45 Lise LISE_CLAUDE CommandLine /url "
http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe"/SN 900-18307653 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid
SESSION_ID
C:\Users\LISE~1.LIS\AppData\Local\Temp\_AI10A9.tmp
2014/9/15:09:48:25 Lise LISE_CLAUDE === Setup ended ===
2014/9/15:09:47:54 Lise LISE_CLAUDE === Setup started on LISE_CLAUDE by
Lise ===
2014/9/15:09:47:54 Lise LISE_CLAUDE Path_Length: 143
2014/9/15:09:47:54 Lise LISE_CLAUDE Current Directory
2014/9/15:09:47:54 Lise LISE_CLAUDE Launch
2014/9/15:09:47:57 Lise LISE_CLAUDE Download Play SETUP_CONFIG
http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...2014/9/15:09:48:14 Lise LISE_CLAUDE Download Complete SETUP_CONFIG
http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...2014/9/15:09:48:15 Lise LISE_CLAUDE PageOpen LaunchDialog
2014/9/15:09:48:41 Lise LISE_CLAUDE PageOpen LicenseDialog
2014/9/15:09:48:41 Lise LISE_CLAUDE PageOpen ProductInfoDialog
2014/9/15:09:48:41 Lise LISE_CLAUDE PageOpen ProductSelectionDialog2
2014/9/15:09:49:45 Lise LISE_CLAUDE PageOpen FullProgressDialog
2014/9/15:09:49:46 Lise LISE_CLAUDE Download Play VCREDIST2012X86
http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...2014/9/15:09:49:52 Lise LISE_CLAUDE Download Complete VCREDIST2012X86
http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...2014/9/15:09:49:52 Lise LISE_CLAUDE Installing Microsoft Visual C++ 2012
2014/9/15:09:53:26 Lise LISE_CLAUDE Install Microsoft Visual C++ 2012
2014/9/15:09:53:26 Lise LISE_CLAUDE Download Play VCREDIST2012X64
http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...2014/9/15:09:53:33 Lise LISE_CLAUDE Download Complete VCREDIST2012X64
http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...2014/9/15:09:53:33 Lise LISE_CLAUDE Installing Microsoft Visual C++ 2012
2014/9/15:09:53:47 Lise LISE_CLAUDE Install Microsoft Visual C++ 2012
2014/9/15:09:53:47 Lise LISE_CLAUDE Download Play DIRECTX
http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...2014/9/15:09:53:54 Lise LISE_CLAUDE Download Complete DIRECTX
http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...2014/9/15:09:53:54 Lise LISE_CLAUDE Installing DirectX® Runtime:
2014/9/15:09:54:18 Lise LISE_CLAUDE Install DirectX® Runtime Succeeded
2014/9/15:09:54:18 Lise LISE_CLAUDE Download Play ADAPPLICATIONMANAGER
http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/ADAPPLICATI...2014/9/15:09:54:45 Lise LISE_CLAUDE Download Complete ADAPPLICATIONMANAGER
http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/ADAPPLICATI...2014/9/15:09:54:45 Lise LISE_CLAUDE Installing Autodesk Application
2014/9/15:09:56:49 Lise LISE_CLAUDE Install Autodesk Application Manager
Succeeded
2014/9/15:09:56:49 Lise LISE_CLAUDE Download Play MAYA
http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/MAYA_en-US....2014/9/15:10:05:57 Lise LISE_CLAUDE Download Error MAYA
Network Error,
cannot downloadCheck connections and try again. Would you like to retry
now?
http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/MAYA_en-US....2014/9/15:10:25:46 Lise LISE_CLAUDE Download Aborted MAYA
http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/MAYA_en-US....2014/9/15:10:25:46 Lise LISE_CLAUDE Install Autodesk® Maya® 2015
Failed Download
2014/9/15:10:26:02 Lise LISE_CLAUDE Rollback Autodesk Application Manager
2014/9/15:10:26:03 Lise LISE_CLAUDE Rollback DirectX® Runtime Failed Failure
2014/9/15:10:26:05 Lise LISE_CLAUDE Rollback Microsoft Visual C++ 2012
2014/9/15:10:26:06 Lise LISE_CLAUDE Rollback Microsoft Visual C++ 2012
2014/9/15:10:26:10 Lise LISE_CLAUDE PageOpen InstallCompleteDialog
2014/9/15:11:03:00 Lise LISE_CLAUDE === Setup ended ===
2014/9/15:11:03:37 Lise LISE_CLAUDE === Setup started on LISE_CLAUDE by
Lise ===
2014/9/15:11:03:37 Lise LISE_CLAUDE Path_Length: 143
2014/9/15:11:03:37 Lise LISE_CLAUDE Current Directory
2014/9/15:11:03:37 Lise LISE_CLAUDE Launch
2014/9/15:11:03:37 Lise LISE_CLAUDE CommandLine /url "
SESSION_ID
C:\Users\LISE~1.LIS\AppData\Local\Temp\_AI84FF.tmp
2014/9/15:11:03:59 Lise LISE_CLAUDE === Setup ended ===
2014/9/15:11:03:48 Lise LISE_CLAUDE === Setup started on LISE_CLAUDE by
Lise ===
2014/9/15:11:03:48 Lise LISE_CLAUDE Path_Length: 143
2014/9/15:11:03:48 Lise LISE_CLAUDE Current Directory
2014/9/15:11:03:48 Lise LISE_CLAUDE Launch
2014/9/15:11:03:53 Lise LISE_CLAUDE Download Skipped SETUP_CONFIG
http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...2014/9/15:11:03:59 Lise LISE_CLAUDE PageOpen LaunchDialog
2014/9/15:11:04:59 Lise LISE_CLAUDE PageOpen LicenseDialog
2014/9/15:11:04:59 Lise LISE_CLAUDE PageOpen ProductInfoDialog
2014/9/15:11:04:59 Lise LISE_CLAUDE PageOpen ProductSelectionDialog2
2014/9/15:11:05:32 Lise LISE_CLAUDE PageOpen FullProgressDialog
2014/9/15:11:05:32 Lise LISE_CLAUDE Download Skipped VCREDIST2012X86
http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...2014/9/15:11:05:32 Lise LISE_CLAUDE Installing Microsoft Visual C++ 2012
2014/9/15:11:05:40 Lise LISE_CLAUDE Install Microsoft Visual C++ 2012
2014/9/15:11:05:40 Lise LISE_CLAUDE Download Skipped VCREDIST2012X64
http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...2014/9/15:11:05:40 Lise LISE_CLAUDE Installing Microsoft Visual C++ 2012
2014/9/15:11:05:47 Lise LISE_CLAUDE Install Microsoft Visual C++ 2012
2014/9/15:11:05:47 Lise LISE_CLAUDE Download Skipped DIRECTX
http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/DIRECTX.tar...2014/9/15:11:05:47 Lise LISE_CLAUDE Installing DirectX® Runtime:
2014/9/15:11:06:00 Lise LISE_CLAUDE Install DirectX® Runtime Succeeded
2014/9/15:11:06:01 Lise LISE_CLAUDE Download Play MAYA
http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/MAYA_en-US....2014/9/15:11:20:41 Lise LISE_CLAUDE Download Aborted MAYA
http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/MAYA_en-US....2014/9/15:11:20:41 Lise LISE_CLAUDE Install Autodesk® Maya® 2015
Failed Download
2014/9/15:11:20:44 Lise LISE_CLAUDE Rollback DirectX® Runtime Failed Failure
2014/9/15:11:20:45 Lise LISE_CLAUDE Rollback Microsoft Visual C++ 2012
2014/9/15:11:20:46 Lise LISE_CLAUDE Rollback Microsoft Visual C++ 2012
Karine Lafranchise
