You are having problems with:
Solved by brian.kling. Go to Solution.
Hi there 12345678i and welcome to the community!
You can get a 3-year student license from the Education Community if you are enrolled in a degree granting institution and meet all the eligibility requirements.
I hope this helps!
Installing as trial and entering the activation code when starting the program for the first time worked for me. Thanks for the tip!
Sorry to toss my hat in the ring especially as a new member, but my copy of autoCAD student is saying the serial is not valid as well. It was a brand new download, and my other downloads worked and activated fine (autodesk 3ds and maya), but not autoCad for some reason. I've noticed Maya , autodesk 3ds and autoCAD share a serial key, so I hope thats not a problem.
Welcome to the Community!
There will share one serial number if you use the same user ID to request all products in Student Community , so please don't worry. And you could verify the product name and version you have requested successfully under your account in Student Community , please review this document. If the product was not under your account, please request it again.
For the serial number issue, you also could send me a Private Message (click on my grace.liu profile name and then “Send this user a private message”) with your Serial Number and Product Key, I will help to check it.
When I try to activate AutoCad 2014 for mac, it gives me an error like "The serial number you entered is not valid. Try again. (1)" However, the serial number is correct from the email. I dont know whats going on 😞
i have dowmloade student version and i got serial no and key...after installation it is showing serial no error ....what should i do....student version id for 3 yrs and i m getting 30 days only.
Hi @Anonymous and welcome to the Autodesk Community!
To reach our Activation and Registration department via Chat for Licensing Help please take the following steps:
1. Visit http://knowledge.autodesk.com/contactus
2. Select “Activation & Registration” or “License Management”
3. Select appropriate subtopics from the pull-down menus.
4. Select “I Still Need Help” if you need personal assistance
If you have any other questions or concerns please let us know. Thank you!
I cant get past step 3 it keeps saying try again in a few minutes and its not working. Im trying to get the codes for AutoCad 2012 before my trial ends. Need this for school.
Hi @Anonymous,
I just checked the page and everything appears to be working correctly. If no chat agents are available please the option to submit a case to the team who will be able to assist you as soon as possible!
Hey there,
I recently attempted to obtain a student license for Maya 2015 through the Education Community. I signed in, selected the appropriate version, language, and operating system from the drop-down menus, and was confronted with a pop-up window stating that license details couldn't be provided at this time. As suggested in the pop-up, I downloaded and installed the product and will be attempting to use it as a trial for 30 days. Every time I check back on the download page, however, I'm still unable to obtain a license for the product.
I've read replies saying to try and chat with someone from support, but the icon says that all representatives are busy, and I can't seem to find a queue to wait for someone to be free. Is there any way to get a license for the product before my trial runs out?
Thanks for any help you can give!
Hi Cory,
Is this true for all Products? Have you tried downloading other Products?
Same problem 😕
Not only with Maya with any Software that requires a new serial number.
In my opinion the "new" Education System is confusing. I dont have any idea how Autodesk can check if I'm realy a student. When the education systems was changed the information about university etc. are no display anymore.
On my Account are a lot of Services listed. Under Products there is only the Software that I have already a serial.
But why I can not get a serial for a new product?
Maybe three years passed? I don't no...
Hi everyone,
We are aware of the issue affecting student version serial numbers and are working to get it resolved ASAP. For now, please download your Autodesk student software (the download button is still enabled after you click off the error message) and use it as a trial (same features as the student version).
Apologies for the inconvenience.
Hello, my name is Olivia Edwards. Autodesk ID - oliviaedwards88
I keep getting a error and try again message when I attempt to get a serial number.
I've been trying for almost 30 days and my trials for both Autodesk AutoCAD & 3DS Max are both running out. I can prove I'm a student with an email from my education authority.
Please can you respond ASAP as I don't want to fall behind with work.
Thank you.
Brian,
As you can see, I have request #170487 which can be verified. WE NEED A SERIAL # AND PRODUCT KEY EMAILED ASAP.
My issue is that I have a design compeition on Monday, and all my designs are inside the APP and my 30 day trial just ended, and I cannot get the system to give me a new serial number.
We've been in this loop now for a while trying to solve it, so we decided to start the 30 day trial and start our designs...and now 30 days later, same issue. So we just created a new user account (this one) and ran into this AGAIN!!! We downloaded
HELP
Hello everyone!
The Education Community serial number issue appears to be resolved! Please try logging into the Education Community at this time and try requesting a serial number. If the problem persists please let us know. Thank you!
