You are having problems with:
Solved by brian.kling. Go to Solution.
Hi @Anonymous,
If you are experiencing licensing issues, please contact our Activation and Registration team directly:
1. Visit http://knowledge.autodesk.com/contactus
2. Select “Activation & Registration” or “License Management”
3. Select appropriate subtopics from the pull-down menus
4. Select “I Still Need Help” if you need personal assistance
There you will be able to chat with a live agent or submit an email if all agents are busy. Please let us know if you have any other questions. Thank you!
@Anonymous wrote:
I need auto cadd 2014 product key and serial no
Simply sign up at the student community http://www.autodesk.com/edcommunity
If your serial number isn't immediately generated - simply run AutoCAD in 30-day trial mode while you wait for it to be generated.
Then when Autodesk e-mails the SN to you, click Activate to activate your 3-yr license beyond the 30-days trial period.
AutoCAD 2015 serial generation always returns:"We're sorry we cannot provide you with your license details at this time..."
Installed AutoCAD in trial mode,but it still wants activation with serial and product code on startup.
Any way to get this registration info?
Hi @vdivnic,
Using the email address on file, I saw that you have already downloaded Autodesk Inventor Professional 2015. Did you download this after or before downloading AutoCAD 2015?
Have you tried downloading previous versions of AutoCAD? Please reply back and let me know, upon reply authorize me as well to reset the password in case there's a need for me to log into your account.
Hello joane.bonghanoy,
I had downloaded and installed Inventor Professional 2015 first,then tried AutoCAD 2015 but without any luck.
Now I have tried to download AutoCAD 2014 and system generates serial info fine.
If we could not activate 2015 version,then I will install 2014 version.
"Please reply back and let me know, upon reply authorize me as well to reset the password in case there's a need for me to log into your account. "
Gladly if You could explain me how.
Hi @Anonymous and welcome to the Autodesk Community!
I'm not sure I completely understand the exact nature of your issue. You downloaded the product successfully and it sounds like you have received the license? Could you please provde further details? Thank you!
Hi @Anonymous,
Please register with the Education Community and select a product which will then provide you the serial number and download. If you have any other questions please contact the education team directly by filling out this problem form.
Thank you,
i have activated my account here and now after signing in when i try to get the license key of AUTOCAD 2015 it says" we are sorry we cannot provide you with your license details at this time " i need the key for my college work .. what to do ??
Hi @Anonymous and welcome to the Autodesk Community.
We are aware of this issue and working to fix it as soon as possible. For now, please use the software on trial mode while we investigate this issue.
Thank you,
I am a new student of AutoCAD 2015 . I have downloaded yuor product AutoCAD 2015 Trial Version from your Autodesk site, installed it but it can't run because it needs product key and activation number. Please can you help me to run it ?
Thank you for help me.
Hi @ahmedelgoharry,
I pulled up your EDU account from the system, however I'm not seeing any downloaded Product as of yet.
Please log into the EDU site with the same User ID as your Forums log in. Download AutoCAD 2015 to receive the Serial #. Click here for the steps on how you can locate the Serial #.
