You are having problems with:
Solved by brian.kling. Go to Solution.
Good mornig,
I have a problem with reactivating my student version of Autocad Inventor Professional 2013. I am trying to activate it on my laptop.
The error message was: "Reactivation Limit Reached" (error 11). I have described Autodesk Support my situation and I had received an activation code from them. However when I am trying to activate Inventor with this code, I get an error 0015.111.
I read many topics about this error, but I cannot deal with it by myself.
If there is a possibility I will agree to give you access to my account, so you can check everything and activate it for me.
Hope you will help me,
Best regards,
Bartosz Szmit.
Hi bartoszs and welcome to the forums,
Can you please send me via Private Message (click on my camilo.lemos profile name and then on Send This User a Private Message) your serial number and a request code obtained from the machine where you're trying to activate the software?
Thank you!
Okay. So here's the deal. Fedora 14 and RHel 6 are supposedly supported. I installed on Fedora 17 and 18. When activating I was getting what everyone else is getting ... NOTHING.
Here is the problem. Fedora 17 and 18 are not supported.
However, CentOS 6 does support it. So I installed CentOS 6. Installed just like in Fedora .. .. Reinstalled video drivers after updating ... And ACTIVATION WORKS!!
So. ... Fedora 17 and 18 couldn't get Maya 2013 to activate ... CentOS got it to work after 1st try.
Your Friend
Raul
I just purchased the Autodesk Entertainment Creation Suite Unlimited 2013 Student version on USB. I entered the product code and student email address and I received confirmation and statement that they sent it to my email but I never recieved an email.
Hi JChed,
You mentioned, you purchased an Education License and entered the Product Code to receive the Serial Number, did you do this via www.identit-e.com/autodesk?
If so and you have not received your Serial Number yet, please send me a Private Message (click on my joane.bonghanoy profile name and then “Send this user a private message”) with the details below:
- Email Address registered
- Order Number
- Product Code (as found on the leaflet inside the box containing the USB)
i'm have a problem getting a serial number and product code for me to re install AutoCAD Design Suite Ultimate. My ex girl friend , I think through my boxd and everything away to the program except the program itself. so now i'm try to reload this to my computer but have no serial number or product code I have sent you a private message with all the information i have please help scho0ol is starting and i don't want to get to far behind
Whenever I try to activate Cad with the Activation Code it responds that there is an Activation-Registration Error (0015.111)
I looked for solutions from Autodesk Customer Support, but they haven't worked.
Hi Michael!
Who did you purchase the license from?
Was the AutoCAD Design Suite Ultimate previously activated? If so can you please send me a Private Message (click on my philip.s profile name and then "Send this user a private message") with the email address used to register it?
Hello Emilio!
Looking at your AutoCAD 2014 activation history it looks like you were able to resolve the issue. Can you verify and or send me a Private Message (click on my philip.s profile name and then "Send this user a private message") with your request code or contact our License Assistance Team if that's not the case.
I have followed the option number 2 for activating 3ds Max.
Actually the serial number and product key are allready in the product activation fields, but when I submit the data to activate I get>> The serial number you entered is not valid. Try again. (1).
Hi Vilius!
Can you please either send me a Private Message (click on my philip.s profile name and then "Send this user a private message") with your serial number + a picture of the activation screen, or contact our License Assistance Team for additional support?
getting problem with activation
attaching the error..
here is asking for activation code. kindly send me one
Product: AutoCAD Mechanical 2012 Serial Number: XXX-XXXXXXXX Product Key: 206D1 Request code: V3NU 5P64 H0L1 WLG7 CFNC U3RG 3YSF HDZZ
Hello Jigar,
As this is a public form, please refrain from posting sensitive information / I edited your response to remove the serial number.
With that being said, I also processed the activation and you should have just received the activation code via email.
Please let me know if we can be of additional assistance!
I'm experiencing an issue where my 30-day trial has expired, but when I click to activate a full version, all I see is a white window with two checkboxes. There's no text with the checkboxes, and can't do anything to get something else to show up. I've uninstalled/reinstalled twice, and it gives the same result. May I have some kind of advice?
Thank you!
Hi ,
I reinstalled my autodesk software afterformatting my pc. I tried to activate the student license but it says "You have already activated your product on the maximum number of computers permitted by your license ". I cant use the LTU since the software was previously installed on the same computer and all of the data has been wiped.
Thankyou !
Hi skas.khurrman,
Can you please send me your serial number and request code via Private Message (click on my camilo.lemos profile name and then on Send This User a Private Message)?
Thank you.
This post has been moved to the appropriate board. Please avoid creating multiple posts for the same issue.
