Installation & Licensing
New Member
perandersholmberg
Message 681 of 1,174 (522 Views)
Re: STUDENTS - Serial Number or Product Key Issues
01-08-2013 10:34 AM in reply to: brian.kling
Hello!
I'm trying to install on Mac OS X 10.8.2 but when typing the product key and license number the application says that the format is not correct. It should be like xxx-xxxxxxxx but my license number is exactly like that.
Please help!
Best Regards
Anders
philip.s
Message 682 of 1,174 (516 Views)
01-08-2013 11:31 AM in reply to: perandersholmberg
Hello Steven and Anders,
Can you both please install the software in trial mode, and then proceed with the standard activation process at first launch which should resolve the invalid serial number error.
Philip Schmelzer
New Member
cjauregui8937
Message 683 of 1,174 (508 Views)
01-08-2013 04:35 PM in reply to: brian.kling
What do you do if when you select your free software, language, OS, and press next, it says "error in assigning serial number to product, this is an operation implementation error?" It gave me a serial number, but it won't work for activating the product after i downloaded it. I activated my license in spring 2011...
Customer Service
joane.bonghanoy
Message 684 of 1,174 (496 Views)
01-09-2013 12:02 AM in reply to: cjauregui8937
Hi cjauregui8937,
We have had some activation issues with our Student Licenses but it has been resolved, however for this particular encountered we would need to look further into.
Do reply back with the following information:
    - Error message when activating the License
    - Screenshot of the error
    - Product Name
Also, I'm making an assumption that you were trying to download a 2011 version from the EDU site when you encountered the error you mentioned. Is that correct?
Joane Bonghanoy
New Member
s1110628002
Message 685 of 1,174 (488 Views)
01-09-2013 01:43 PM in reply to: brian.kling
hi,
i too have a problem with my serial number, i get the error:
The serial number you entered is not valid. Try again. (1)
philip.s
Message 686 of 1,174 (484 Views)
01-09-2013 03:11 PM in reply to: s1110628002
Hello Isabella and welcome to the community!
Can you please send me a Private Message (click on my philip.s profile name and then "Send this user a private message") with the serial number and product name that you are getting this error with.
Philip Schmelzer
New Member
tlegras
Message 687 of 1,174 (483 Views)
01-09-2013 03:17 PM in reply to: brian.kling
I succeed to have a serial numner and a product key. The set up ran well with no trouble. Then when I open Revit 2013, the validation windows don't pop well (cf file 1). I do Alt+F4 then the windows for the choice between the trial or the validation appears (cf file 2). I choose activate and then again a windows pops up but doesn't succeed to show the information properly (cf file 3).
I test does pages (which are just html) with google chrome and it shows all the information if I authorize the script to run on the page. So it seems to me that when Revit is starting, it doesn't succeed to run the script. (I put the information ask when I used google but it doesn't work either)
I try to do it without antivirus but it doesn't change anything. I try to set up again Revit  but again not working
Could you help me ?
PS : I am using W7 64bits with 8Go of RAM and a Intel Core i7
philip.s
Message 688 of 1,174 (472 Views)
01-09-2013 03:34 PM in reply to: tlegras
Hi Thibault,
The blank activation screen (displaying two radio buttons) is actually a known issue with several potential workarounds. Check them out here on our AutodeskHelp Pinterest board.
Philip Schmelzer
New Member
andrea.behme
Message 689 of 1,174 (453 Views)
01-10-2013 06:39 AM in reply to: s1110628002
I have the same problem. It shows me the error: The serial number you entered is not valid. Try again.
And in "My software" the AutoCAD 2013, I have downloaded, is not listed.
But in the program and autodesk said it is the right serial number.
I hope somebody can help me.
Member
carolin.schottenheimer
Message 690 of 1,174 (444 Views)
01-10-2013 08:28 AM in reply to: perandersholmberg
Hello Every one. I have a Problem with the support.
I write at the 13th of december to:
rtxml-emea@activation.autodesk.com
the atumatic generated e-mail (Autodesk ctivation custumer confirm), that my serial number couldn't be activated. I couldn't found any other e-mail adress or support. I am not sure if my e-mail reach the company.
Could anyone help?
Thank you very much.
