Installation & Licensing
177 Kudos
Post 671 of 1,174
Re: STUDENTS - Serial Number or Product Key Issues
01-03-2013 05:33 AM in reply to: courtenay10
Hi courtenay10,
I'll be happy to activate your Revit manually. All I need is for you to send me your serial number and the program's request code via private message here on the forums (click on my screenname camilo.lemos and then on Send This User a Private Message).
Camilo Lemos
New Member
0 Kudos
Post 672 of 1,174
01-03-2013 09:08 PM in reply to: brian.kling
Hi there,
i am having a very similar problem here
I keep getting this message when I go to the download section
We're sorry we cannot provide you with a serial number at this time.
Please proceed to download and install your software, and use it in "trial mode" for up to 30 days.
Return to this site before then to obtain your serial number from the free software link.
my 30 days has expired and i am still unable to get a serial code that works, this ahs been going on for some time now.
Customer Service
71 Kudos
Post 673 of 1,174
01-03-2013 10:34 PM in reply to: syd105552
Hi Alfred,
We had this issue previously but has been resolved. However, no worries, we will look further into this.
Case Number 07942798 was created for this and I will keep you posted with the resolution and your Serial Number via the Case Number and the email address we have on file.
Joane Bonghanoy
New Member
0 Kudos
Post 674 of 1,174
01-06-2013 02:28 PM in reply to: brian.kling
Hi
I have a serial umber and a product key but when I enter them in the installer, it displays an error message that approximately says that it is not valid.
My serial number is xxxx-xxxxxxxx and Product key 777C1
Thanks for your answer
20 Kudos
Post 675 of 1,174
01-07-2013 12:23 AM in reply to: djuna.patin
Hi djuna.patin:
The serial number you have provided is for AutoCAD for Mac 2011. Please make sure you have the correct product installed on your machine. You can verify the serial numbers associated to your product in Education Community site by clicking on "My Software".
Also, note I have removed your serial number information for security reason since this is a public forum. :smileyhappy:
Let me know if you have encountered any further issue.
Best Regards,
Arlin Bibat
177 Kudos
Post 676 of 1,174
01-07-2013 12:32 AM in reply to: djuna.patin
Hi djuna.patin and welcome to the forums!
As an initial tip, please do not post sensitive information (such as your product's serial number) on the forums as it can compromise the security of your software and your account.
It looks like you're trying to activate AutoCAD for Mac 2011, can you please try this solution for your activation issue and let me know if it works?
Thank you!
Camilo Lemos
New Member
0 Kudos
Post 677 of 1,174
01-08-2013 02:04 AM in reply to: camilo.lemos
Hi!
I'm having an issue with my Product key when I try to install the service pack 2 for Autodesk Maya 2013.
Autodesk Maya 2013 is listed in "My Software" and the installer accepts the serial number, but not the product key.
What can I do?
177 Kudos
Post 678 of 1,174
01-08-2013 02:22 AM in reply to: eivindhbrenna
Hi eivindhbrenna,
I don't see Maya 2013 registered on your profile, I can see Maya 2012 and 3ds Max 2013. Can you please double-check that you are trying to update/activate the correct version and software?
A list of product keys for the latest versions of our software can be found here.
Let me know how it goes, please:smileyhappy:
Camilo Lemos
New Member
0 Kudos
Post 679 of 1,174
01-08-2013 02:27 AM in reply to: camilo.lemos
You're absolutely right!
I was trying to register with the 3ds product key ...
Need more coffee...
Thanks for your time :smileyhappy:
New Member
0 Kudos
Post 680 of 1,174
01-08-2013 09:42 AM in reply to: brian.kling
I entered the provided serial number and product key for AutoCAD 2012 for Mac when trying to install and I get an error of "The Serial Number or Product Key don't Match.
Valid format for serial number is (XXX-XXXXXXXX)" when trying to register.
What do I do? The numbers are exactly what I was emailed.
Steven Tate
