I have a problem with the licensing when I try to open Maya 2014 SP3. It says that I have reached the activation limit for it.
At first, I had the student version of Maya 2014 which I was trying to install on my Mac since I work on it. I have it also installed on my desktop and on Bootcamp on my Mac, in case I need it. I had trouble installing the student version of Maya 2014 and when I've searched for a solution for that problem, they've said to install Maya 2014 SP3; So I did. But now, I cannot license it because it says that I have reached the activation limit for it.
Please help, I need it for my college assignments.
Solved by camilo.lemos. Go to Solution.
Hi @julianwmtan and welcome to the Autodesk Community!
Student licenses are only supposed to be installed and activated on one computer, hence the activation limit issue.
As you needed to install and activate SP3 (in practice, a mandatory reinstallation and activation of the same product), I can help you by activating this manually for you. But please keep in mind that the program should only be used on one computer.
Please, send me your serial number and request code via Private Message (click on my camilo.lemos profile name and then on Send This User a Private Message) and I'll look into this for you.
Thanks!
