Installation & Licensing
Student having trouble installing Inventor 2012
5 REPLIES 5
394 Views, 5 Replies
Every time I try to install Inventor 2012 I get "Installation complete. Some products failed to install." Here is my installation log file:
2014/8/6:15:05:00 owner OFFICE === Setup started on OFFICE by owner ===
2014/8/6:15:05:00 owner OFFICE Launch
2014/8/6:15:05:15 owner OFFICE Inventorui== Parameter: Prereq_1 SetupMode:1 InstallState:1 InstallAction:0 Message:
2014/8/6:15:05:15 owner OFFICE Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2014/8/6:15:05:15 owner OFFICE Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2014/8/6:15:05:21 owner OFFICE Inventorui== Parameter: Prereq_4 SetupMode:1 InstallState:2 InstallAction:0 Message:
2014/8/6:15:05:22 owner OFFICE PageOpen LaunchDialog
2014/8/6:15:06:09 owner OFFICE PageOpen LicenseDialog
2014/8/6:15:06:12 owner OFFICE PageOpen ProductInfoDialog
2014/8/6:15:06:32 owner OFFICE PageOpen InventorFlavorSelectionDialog
2014/8/6:15:06:33 owner OFFICE Inventorui==DefaultLanguage: en-us
2014/8/6:15:06:33 owner OFFICE Inventorui==InstallName: INVENTOR
2014/8/6:15:06:33 owner OFFICE Inventorui==ProductName: Autodesk Inventor 2012
2014/8/6:15:06:33 owner OFFICE Inventorui==DisplayName: Autodesk® Inventor® 2012
2014/8/6:15:06:33 owner OFFICE Inventorui==DeploymentName:
2014/8/6:15:06:33 owner OFFICE Inventorui==SetupTitle: Autodesk Inventor 2012
2014/8/6:15:06:33 owner OFFICE Inventorui==ConfigTransform:
2014/8/6:15:06:33 owner OFFICE Inventorui==ExeParams:
2014/8/6:15:06:33 owner OFFICE Inventorui==ProductCode: {7F4DD591-1632-0409-0000-7107D70F3DB4}
2014/8/6:15:06:33 owner OFFICE Inventorui==SupportLink:
2014/8/6:15:06:33 owner OFFICE Inventorui==InfotainmentLink:
2014/8/6:15:06:33 owner OFFICE Inventorui==MsiFileName: inventor.msi
2014/8/6:15:06:33 owner OFFICE Inventorui==AdminImageConfigName: AdminImagex86
2014/8/6:15:06:33 owner OFFICE Inventorui==AdminImageRoot:
2014/8/6:15:06:33 owner OFFICE Inventorui==GetBaseDeploymentName:
2014/8/6:15:06:33 owner OFFICE Inventorui==DeploymentLocation:
2014/8/6:15:06:33 owner OFFICE Inventorui==DocumentLink: SetupRes\InfoLink\help_landing.html
2014/8/6:15:06:33 owner OFFICE Inventorui==InstallDeploymentShortcut:
2014/8/6:15:06:33 owner OFFICE Inventorui==ModifyDeploymentShortcut:
2014/8/6:15:06:33 owner OFFICE Inventorui==SetupLockType: 2
2014/8/6:15:06:33 owner OFFICE Inventorui==SetupNetworkType: 0
2014/8/6:15:06:33 owner OFFICE Inventorui==SystemLocale: 1033
2014/8/6:15:06:33 owner OFFICE Inventorui==EvalMsiFilePath: C:\DOCUME~1\owner\LOCALS~1\Temp\_AIE8F.tmp\SetupRes\eval.msi
2014/8/6:15:06:33 owner OFFICE Inventorui==EulaPath: C:\DOCUME~1\owner\LOCALS~1\Temp\_AIE8F.tmp\EULA
2014/8/6:15:06:33 owner OFFICE Inventorui==InstallLogPath: C:\DOCUME~1\owner\LOCALS~1\Temp\Inventor2012Install.log
2014/8/6:15:06:33 owner OFFICE Inventorui==ConfigFile: C:\DOCUME~1\owner\LOCALS~1\Temp\_AIE8F.tmp\Setup.ini
2014/8/6:15:06:33 owner OFFICE Inventorui==SetupPath: C:\Autodesk\Autodesk_Inventor_2012_English_Win_32bit\
2014/8/6:15:06:33 owner OFFICE Inventorui==NetworkLogPath:
2014/8/6:15:06:33 owner OFFICE Inventorui==SourceRoot: C:\Autodesk\Autodesk_Inventor_2012_English_Win_32bit\
2014/8/6:15:06:35 owner OFFICE Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2014/8/6:15:06:35 owner OFFICE PageOpen ProductSelectionDialog2
2014/8/6:15:07:05 owner OFFICE PageOpen FullProgressDialog
2014/8/6:15:07:05 owner OFFICE Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2012_English_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/8/6:15:07:08 owner OFFICE Install Autodesk Material Library 2012 Failed Installation aborted, Result=1601
Help would be greatly appreciated!
5 REPLIES 5
DannyHubbard
The 1601 error would indicated that you are out of or low on disk space.
From your log file:
How much free space on your C drive?
Danny
Danny Hubbard
QA Analyst
in reply to: DannyHubbard
I have 30 gigs. I also tried downloading it on external hard drive with over 100 gigs free space. Same message.
DannyHubbard
First thing try deleting everything in your TEMP folder, should be something like "C:\Documents and Settings\owner\Local Settings\Temp".
Then "Enable Windows Installer Logging", see http://support.microsoft.com/kb/314852
Try installing Inventor again, if it fails at the same point go back to the TEMP folder an post the MaterialLibrary2012 log files from this folder. They should give us more detail about why it is failing to install.
Thansk,
Danny
Danny Hubbard
QA Analyst
This is what the new file in the temp folder reads:
=== Verbose logging started: 8/7/2014 11:12:01 Build type: SHIP UNICODE 4.05.6001.00 Calling process: C:\Autodesk\Autodesk_Inventor_2012_English_Win_32bit\Setup.exe ===
MSI (c) (FC:74) [11:12:01:859]: Resetting cached policy values
MSI (c) (FC:74) [11:12:01:859]: Machine policy value 'Debug' is 0
MSI (c) (FC:74) [11:12:01:859]: ******* RunEngine:
******* Product: C:\Autodesk\Autodesk_Inventor_2012_English_Win_32bit\Content\ADSKMaterials\2012\CM\MaterialLibrary2012.msi
******* Action:
******* CommandLine: **********
MSI (c) (FC:74) [11:12:01:859]: Client-side and UI is none or basic: Running entire install on the server.
MSI (c) (FC:74) [11:12:04:859]: Failed to grab execution mutex. System error 258.
MSI (c) (FC:74) [11:12:04:859]: Failed to connect to server. Error: 0x80070003
MSI (c) (FC:74) [11:12:04:859]: MainEngineThread is returning 1601
=== Verbose logging stopped: 8/7/2014 11:12:04 ===
DannyHubbard
You might try reinstalling the Windows Installer then try Inventor again.
http://support.microsoft.com/default.aspx?scid=kb;en-us;315346#method2
Danny
Danny Hubbard
QA Analyst
Administrator Productivity
